68 needs 327 again
Old Aug 24, 2004 | 09:32 PM
c3nut's Avatar
c3nut
5th Gear
Default 68 needs 327 again
Whats up guys, First thanks to all who helped me w/ my vibration problem. Ok I have been restoring my 68. Everything is new, but I bought it w/ a 350. I would love to put an oem 327 back in. any ideas were I can find one to rebuild(or new). I have tried all of my junk yards.
Thanks,
C3nut
Old Aug 25, 2004 | 12:24 AM
T-Top Tom 1
Guest
Posts: n/a
I have a 1968 corvette bare block that you might be interested in.
Old Aug 25, 2004 | 07:54 AM
markdtn's Avatar
markdtn
Did you find any 307s in your junkyard? A 307 and a 327 have the same crankshaft. Use your 350 block and you have a 327. Probabaly have to have it balanced. If you must have a 68 327 that will be harder.
Old Aug 25, 2004 | 10:45 AM
markdtn's Avatar
markdtn
Don't know where in the country you are, but I just spoke to my friend who is on his way to Carlisle (if you are near there-go). He has a 327 complete in a '68 roadster. He is in Atlanta, GA. Won't be back until next Wednesday. If you are interested call him then. 770-461-5211.
Old Aug 25, 2004 | 04:51 PM
MPSJM's Avatar
MPSJM
I have the opposite problem I have a 68 327 in my 69 which should have a 350 in it.
Old Aug 25, 2004 | 06:08 PM
Chuck Gongloff's Avatar
Chuck Gongloff
Active Streak: 90 Days
If you're doing a NCRS/Bloomington type restoration, you'll need a 327 block with the correct casting number and a correct casting date which would be "correct" for the build date of your car. Several engine block vendors advertise in Hemmings. They have blocks with every conceivable casting number and date. Classic Engine Company and Engines Unlimited are two that come to mind. Both are located in Wisconsin. Chuck
To 68 needs 327 again
