Gonna have me the COOLEST C3!
Location: San Diego - Deep Within The State of CONFUSION!
Almost done glueing the Reflectix down. Just now remembered that there's foil TAPE too for the edges! Thank goodness for Budweiser and cool nights! The POR15 was put on over the coating of RustOleum that was already posted. Thanks again to Cali,68.
Yes that's reflectix over the Differential hump Also there's Reflectix over the top of the driveshaft tunnel toward the rear, under the molding. Only thing left before the carpet, is to put Reflectix over the shifter area of the tunnel! It's really late now though and I think that can wait a day.
ride Paul....keep up the good work. Ya know, the only thing I don't like about the reflectix is that "crunching" sound when you step on the carpet. Oh well...small price for cool feet!
Good Luck
Eddie
Good Luck
Eddie
CI 7-8 Veteran
Paul - Don't forget the seat back area and also, if you haven't already done it, make sure and put in the foam collar on the bellhousing that stops the airflow of hot engine air into the tranny tunnel.
You're going to be MUEY surprised with a COOL ride!
Originally Posted by Ganey
Paul
Later models like 77- came from the factory w/ similiar. The A/C duct to dash end vent can be opened to the floor.
While the dash has been out, I've resealed the whole A/C system includeing all the foam seals and taped seals in the ducting. It's been a few weeks now and I'm SOOOOO anxious to finish her up!
Originally Posted by Corey_68
Keep any unwanted heat and noise out from coming inside the car.
