1970 Cpe Electrical Problem
Old Aug 25, 2004 | 02:04 PM
dizzyd's Avatar
dizzyd
5th Gear
Default 1970 Cpe Electrical Problem
Hi All!
I'm new to this forum so I'll try to be brief. My nephew owns a 1970 Vette Cpe w/350. The car will start and run w/o any problem. When it sits for about a week or less the battery has drained too far to start it. He applied a "Battery Tender" (charges at about a 1 amp rate, I believe) after disconnecting the battery ground cable. Tried it again about 3 days later---started fine. Shut it off; 3 days later, dead again. We checked the battery circuit by removing the ground cable and putting a test light between the negative battery post and the negative cable---light is 'ON'. Tried pulling all fuses---light still 'ON'. Started removing all the wiring that's non-fused, one circuit at a time--light still 'ON'. Is it possible that the battery is bad? He claims it's only 8 mos. old (Interstate). Or is it also possible that the negative cable is not making good enough ground at the rear cross member? We looked at it and it appears pretty cruddy! I'm no electrical expert but I've done lots of circuit tracing on British cars over the years---maybe I'm too old to think straight but this one has me ticked off now!! Any help would be greatly appreciated.
Old Aug 25, 2004 | 06:23 PM
72GACRZR's Avatar
72GACRZR
I seem to recall that can be caused by the alternator. I am trying to find a past thread.
Here's one, but not the one I remembered
http://forums.corvetteforum.com/show...t=dead+battery
Here it is
Old Aug 25, 2004 | 08:29 PM
gearheaddroppings's Avatar
gearheaddroppings
St. Jude Donor '05-'06-'07-'08-'09-'10
It seems that you have gone through all of the proper circuit tests. This was a problem on my '70 and I discovered that it was the center compartment door behind the seats. If it is not shut the whole way, the light inside will slowly drain the battery in around 3 days. Good luck.
Old Aug 25, 2004 | 09:01 PM
BatManFire's Avatar
BatManFire
Well if you had the battery disconnected from any charging source and it was full charged when you let it set for 3 days I'd say you have a wore out or bad battery.
The alt if the diodes/reg/stator are blown out they will drain the battery just like leaving a dome light on. If you run a voltage test across the (full charged GOOD) battery it should charge about 13.8-14.2. If its above that its most likely the regulator causing the problem if its below 13.8 it still could be the reg, stator or diodes. If its just battery voltage say 12.5 and stays there no matter what it could be anything.
If your battery is getting old 3 1/2-4 yrs old make sure you invest into a new battery. A battery is the most important part of the electrical system.
Old Aug 26, 2004 | 02:19 AM
70ZZ3 96LT4's Avatar
70ZZ3 96LT4
Default 70 Electrical
Have a 70 myself with a old, old Interstate battery installed in Dec of 1996. Still cranking. Check the wiper override switch and see if it could be turned on. If it is on it will draw current all the time.
Old Aug 26, 2004 | 01:23 PM
dizzyd's Avatar
dizzyd
5th Gear
Thanks guys for your responses.
As far as the alternator/regulator system, I believe we eliminated that when we disconnected ALL the hot circuits we could find. THe red lead on the alternator was disconnected while watching the connected test light and it still remained on. We've even disconnected ground leads from some of the charging/starting circuits as well. As for the battery, even though he purchased it new 8 months ago, there is the possibility that it developed a problem. He doesn't seem to have a problem getting it to take a charge, it's while sitting that it drains. I'm still waiting for him to have it checked out. When charged, it seems to hold a steady 12.5-12.8volts. While charging, it's steady at about 14.5 volts. Thanks for the heads up on the wiper over-ride switch and rear compartment door! I've asked my nephew to remove as much of the circuit wiring from the dashboard as possible to at least get it down to one certain area---would certainly make finding this short a lot easier. My suggestion to him was to remove the battery from his 1998 Chevy pick-up and try the same tests again. Until we can find a better wiring diagram, there's not much else I'd attempt to do at this point. Thanks again all!!
Old Aug 26, 2004 | 05:41 PM
72GACRZR's Avatar
72GACRZR
Unless I am mis-reading your first post, the test light isn't going to tell you anything, because it will light by itself if it is the only thing between the positive and negitive post, as it completes a circuit.
Read the past threads about using a meter to check.
Old Aug 27, 2004 | 04:03 PM
dizzyd's Avatar
dizzyd
5th Gear
Sorry but you have mis-read. What I did was connect a test light between the negative cable (removed at battery) and the negative battery post. Light was consistantly on throughout all circuit tests. Could not find a circuit that was shorted to ground any where in the car. That's not to say that we found All the circuits---the diagram we used left a lot to be desired!!!
To 1970 Cpe Electrical Problem
