Text for 80 & 82 Fusebox Needed
Old Aug 25, 2004 | 04:02 PM
djunod's Avatar
djunod
Default Text for 80 & 82 Fusebox Needed
Does anybody have a photo that shows the silk screen text for a ’80 and a ’82 fusebox? (they are different)
I can’t see under there very well, and am getting tired of pulling each fuse to find the blown one.
Old Aug 25, 2004 | 05:42 PM
Xakk's Avatar
Xakk
Sorry, mine's a couple hundred miles away right now, but save yourself some time. Get you a test light, clip one end to the door buzzer switch, and tap the metal pieces on each fuse. The one that doesn't light up is generally the one that's blown.
-Xakk
Old Aug 25, 2004 | 06:10 PM
bs82vette's Avatar
bs82vette
Default Silk Screen?
What the ??? is that???? Silk Stockings but what are you describing?
Old Aug 25, 2004 | 06:26 PM
djunod's Avatar
djunod
Both 80 & 82 use "modern" push-in fuses, with no metal exposed.
The white text on the fuse box appears to be silk-screened onto the box. The text tells what each fuse is for. My stockings have a run... can't read them any more.
Old Aug 25, 2004 | 06:34 PM
bs82vette's Avatar
bs82vette
Default Silk Huh?
You mean the 81/2 x 11 page 7-5 from the owners manual?Yea i gottit.Wanna Fax?You have my card call me.I'm retired remember?Yea i had cadillacs in both eyes and can't see good too.Still got cadillac in left eye.Miss Carol is stylish on this computtin stuff.She says she can send the Silk to you at your email address.
Old Aug 25, 2004 | 08:07 PM
bs82vette's Avatar
bs82vette
Default Need for 80
Need copy of pictorial page in 80 owners manual of Fuses and Circuit Breakers.Scan and send to David
Old Aug 25, 2004 | 08:55 PM
Xakk's Avatar
Xakk
Even modern fuses have a small piece of metal exposed over each post, just big enough to hit with the test light.
Old Aug 25, 2004 | 09:16 PM
Avette4me's Avatar
Avette4me
Cruise-In VIII Veteran
From the '80 shop manual (I have a brand new Helm in the box if you're interested in a deal)...
anyway, hope this works for ya...
Old Aug 25, 2004 | 11:16 PM
djunod's Avatar
djunod
Thanks Butch & Avette4me that's exactly what I needed.
Xakk, that method is empirical and mostly a waste of time, not to mention difficult. The easiest & quickest (therefore best) method is to go with the documentation: if something doesn't work, look up where it is on the fuse box and go straight for the fix.
Old Aug 26, 2004 | 07:29 AM
Xakk's Avatar
Xakk
Each to their own I guess. For me, that's the fastest and easiest way to check to see if I have a blown fuse. In just under a minute or so, I can hit all the fuses in the box. If it doesn't light up, pull it out and check it. Also helps to track down those things that don't have their own fuse, especially if you don't have the documentation handy. But hey, what ever works.
-Xakk
Old Aug 26, 2004 | 07:33 AM
Twin_Turbo's Avatar
Twin_Turbo
To Text for 80 & 82 Fusebox Needed
