Flushing Brake Lines?
Old Aug 26, 2004 | 12:38 PM
70_Shark's Avatar
70_Shark
Default Flushing Brake Lines?
I'm still bleeding out very dirty brake fluid from my lines. Is there anything that really cleans out the lines that is not hard on the caliper seals and the residue won't hurt the fluid? I have a lot of 99% and 70% isopropyl alcohol here at work.
Thanks,
-Dan
Old Aug 26, 2004 | 01:22 PM
MILO's Avatar
MILO
I'm pretty sure that you need to flush out the lines with denatured alcohol. As far as the calipers and master cylinder are concerned, I would try to flush with a syringe, tube and clean brake fluid. If you don't want to take everything apart, I would just keep buying break fluid and keep flushing with a vacuum pump or pressure bleeder.
Good Luck.
Old Aug 26, 2004 | 03:41 PM
comp's Avatar
comp
you can get a big bottle of cheap Dot 3 to use
Old Aug 26, 2004 | 04:24 PM
70_Shark's Avatar
70_Shark
Thanks, That is what I will do.
Old Aug 26, 2004 | 04:30 PM
mvftw's Avatar
mvftw
This what you need...
http://www.motiveproducts.com/02bleeders.html
Old Aug 26, 2004 | 04:35 PM
Marv's Avatar
Marv
Keep away from the brake pedal during this operation. Use a turkey baster to suck all the fluid from the master cylinder then wipe the crud out of the bottom carefully with a lint free/clean cloth. Then refill with new fluid and gravity bleed in the correct order. 1 quart of fluid is approximately 3 times the brake system capacity. Don't forget those inner rear bleeders. Have fun.
Old Aug 26, 2004 | 08:02 PM
R. Bruno's Avatar
R. Bruno
Originally Posted by mvftw
That pressure bleeder look pretty nice. I know it can be built for less, but for $54 I might spring for one.
Old Aug 26, 2004 | 08:05 PM
Twin_Turbo's Avatar
Twin_Turbo
99$? Wow, I made mine a lot cheaper than that. Flat piece of aluminuim, piece of rubber (actually old lid seal from truck) cur ro expose pressure hose conenction, then hook it up to a compressor or even a small bicycle tire pump will do, overall cost maybe 5$
As for the slits for the clamps, a pair of c-clamps are real handy for clamping a plate down, those one hand pull trigger clamp devices are even nicer and most people have one or the other... 50$ saved, hello new performance parts
Old Aug 26, 2004 | 08:07 PM
CruisinCO's Avatar
CruisinCO
Get the motive bleeder... it works wonders in minutes... i'd suggest also getting either C-clamps or hex nuts to hold down the attachement to fit your MC because the wing nuts they provide are worthless.
Old Aug 27, 2004 | 07:11 AM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
I have used and love the Snap-on vacuum unit. It connects to a regular air line, but sucks the fluid out at the caliper bleeder. You watch the fluid come out, stop it when there's no bubbles.
Old Aug 27, 2004 | 07:31 AM
70_Shark's Avatar
70_Shark
I pumped a large bottle of dot 3 through the system last night. Once the collection jar settled, there are four distinct layers that seperated. Yellow on the bottom, reddish brown(the most volume), dark brown and the top layer a milky clear.
It is running clear now but for $4.00 another big bottle goes through tonight.
Why should I stay away from the brake pedal?
I'm going to make a flusher like twin_turbo suggested today here at work.
-Dan
Old Aug 27, 2004 | 07:58 AM
70_Shark's Avatar
70_Shark
One more quick question. When I was at NAPA yesterday I noticed they carried Dot 3, Dot 4 and Dot 5. I have stock rebuilt calipers. I know that there is also synthetic. What should I use when I finish flushing the system.
Thanks!
Old Aug 27, 2004 | 11:09 AM
aussiejohn's Avatar
aussiejohn
70 Shark,
I have used methylated spirits for decades to flush out brake fluid. It works fine and it's cheap. It helps to use coloured brake fluid (most are!) when filling so you can see the difference between metho and brake fluid.
Regards from Down Under
aussiejohn
Old Aug 27, 2004 | 03:33 PM
70L46Conv4Sp's Avatar
70L46Conv4Sp
A Mityvac for about $40 works well too. You can get them at any Pep Boys.
To Flushing Brake Lines?
