'68 fuel guage troubleshooting...HELP!
How should the system work? Where should the power for the guage originate? I did notice a third post near the back of the fuel guage with nothing attatched, and there is what appears to be some sort of resistor dangling behind the instrument cluster that looks like it should be attatched to an electrical post somewhere, but temporarily fastening it to the stud next to the fuel guage didn't change anything.
where do I go from here?
-Roy
I know the sending unit in the tank changes the resistance as it goes up and down. At the sending unit under the tank the black wire should go directly to a good ground (important!) I know with mine the wiring harness was so fubared we just ran a new wire from the fuel guage back to the sending unit. I also remember testing the guage by sticking a wooden dowel into the tank, pushing down on the sending unit and watching the resistance change on my ohm-meter. Hopefully someone else can fill in the many blanks.
The TAN (brown) wire goes directly to the gauge through a multi pin (12 pins) connector behind the dash. On the back of the gauge there is a 2 pin connector with the TAN/brown and a pink wire. The pink has the volts when ignition is switched on at the key. the pink comes from the fuse box.
I think the resistor thingy mentioned is a trim resistor to give exactly a full reading when full.
See if the TAN/brown wire reads between 0 and 90 ohms to ground approximating the level of fuel in the tank. I think the black wire at the gauge is either Bubba at work or someone has accidently put the ground for the cluster on the wrong tag.
Have fun getting all the bulbs back in the cluster!
I'll check the black wire at the back to be sure it's grounded.
The funny thing is, there is a two prong female connector that hooks to the back of the fuel guage, with BLACK and BROWN wires running away, that appears to be factory made, not Bubba, and the wires are identical in color to the two that leave the sending unit. Where's the pink???
I was thinking there might also be pressed into the sheetmetal housing coding which indicates the colors of wires and where they are connected. I am sure they did that on the speedo and Tach. I think the connectors were different so you could not put the wrong one in the right place. Anti bubba at the factory you might say.
Look for the resistance first to confirm you have continuity between the sender and the gauge. Check to see if the black on the gauge is ground as well.
