How do u remove strud rod shaft?
Old Aug 26, 2004 | 06:04 PM
Smokin Joe's Avatar
Smokin Joe
Default How do u remove strud rod shaft?
Is there an easy way to remove the strut rod shaft from the T arm assembly and the strut rod?
Old Aug 26, 2004 | 06:10 PM
zwede's Avatar
zwede
You're talking about the shock mount, I guess? The shock mount also holds the strut rod. Some shock mounts come out easily, some are almost welded in place. I got lucky on mine. I loosened the castle nut, whacked it with a hammer and it came loose on the first whack.
Old Aug 26, 2004 | 06:15 PM
Schmucker's Avatar
Schmucker
I was unlucky with mine and had to cut, drill, and beat it out.
Old Aug 26, 2004 | 06:17 PM
Smokin Joe's Avatar
Smokin Joe
yeah the shock mount...it depends on the book you read as to what they call it. I'm having Van Steel rebuild the Tarms, so I guess I can leave the tie rod on as per his websight and give it to him that way. I am going to try a ball joint splitter real quick. I wonder if that would help any.
Old Aug 26, 2004 | 06:24 PM
Ganey's Avatar
Ganey
Remove the shock mount the way the car sits, i.e. jack spring & loosen adj. instead of jacking the car & letting it hang down.
To How do u remove strud rod shaft?
