Cross-fire Computer Change Out?
http://www.turbocity.com/product_inf...roducts_id=455
Jerome
there are MUCH better solutions out there.
Get a 7747 + the calpak. Then get the edge card connector from http://www.speedtronics.net They also have a prominator in various versions. This little device eliminates the irritating prom burning/erasing procedure and lets you program the flash memory on it to mimic the prom, in fact with a dipswitch you can select multiple bins for instance for performance, conomy, valet ...etc. The amount of bins it can hold is dep[endent on mem. size. The Prominator comes with it's own software
The company is run by 2 upstanding guys, their products are second to none and you will really love the instant on the fly tunability and the other awesome features. Contact Bill Hitchkock or Ken Kelly for more info (see site) Basically, they just used all the info that others have offered for free and devoted their spare time to and are trying to make a quick buck. It used to cost 400$, I see it's 500$ now...well well... somewhere the price of proms must have gone up w/ 100$ or so
To read the serial data get Jonas Bylund's WinBin, it's free.
The reason TC uses the 7747 ECM is because it's also a TBI ECM (and it will run the CFI (the dual IAC circuit is no biggie, it's a parrallel setup anyway) The 7747 is one of the most hacked ECMs out there, codes are widely known so tuning bins are available. Do a search on GM-ECM and DIY-EFI and you will see the vast amount of knowledge out there, most of it on the 7747 and the 8746, which is also a TBI ECM but it has a MAT sensor input and a lean cruise mode (NICE!), the 8746 ECM is still being worked on but gaining popularity.
Anyway, she is back up and running with noticeable gains.
Thanks!
I put one of these chips in the wife's 82 to also get rid of the lockup in the lower 3. The car ran fine for awhile, but now idles eradicly and a little high. Do you think a change back to the 180 thermostat is in order. Also you mentioned timing, factory specs?
Thanks, Jerome
