Transmission Fluid Change?
Old Aug 27, 2004 | 09:13 AM
Grinchia's Avatar
Grinchia
Default Transmission Fluid Change?
Should I be replacing the fluid in my M-21 at some interval? If so, how often, what fluid, and is there a relatively un-messy way to do it?
-Roy
Old Aug 27, 2004 | 04:56 PM
Grinchia's Avatar
Grinchia
TTT
surely somebody out there has faced this question before?
-Roy
Old Aug 27, 2004 | 05:18 PM
comp's Avatar
comp
once a yr. is ok if you don't beat on it bad
Old Aug 27, 2004 | 06:01 PM
stingr69's Avatar
stingr69
Change it every few years. If it does not have a drain plug you need the giant hand syringe to suck out all the fluid.
-Mark.
Old Aug 27, 2004 | 06:50 PM
joe73vette's Avatar
joe73vette
Manual trannys should have the oil changed every time they are removed from the car. Other than that, they're fine. Just check the level periodically and top off as needed. Joe
To Transmission Fluid Change?
