How do I fix this Dash??
Old Aug 27, 2004 | 11:39 AM
kermit1654's Avatar
kermit1654
Default How do I fix this Dash? - FOLLOW UP- With Picture
I been looking at this on my '78 dash since I bought it and it really bothers me. The dash isn't cracked. It looks like a section of the dash cover was cut out?
Is there any way to fix this without replacing the dash?
FOLLOW UP BELOW:
Used 80TEXASC3's advice and tried the CA glue. It took me about 3 days of slowly building up the thin layers of the glue and sanding, but I think it going to turn out pretty good. I just put a coat of painted on the damaged area for now and it's looking pretty good. Alittle more sanding and once I repaint the entire dash I think it will be good as new. I want to give a big thanks to 80TEXASC3 and everyone else that helped. This forum shows, once again, that is more valuable to have than any repair manual ever could be!
Old Aug 27, 2004 | 11:41 AM
nhlgopens's Avatar
nhlgopens
Bubba says "duct tape"... seriously, I think your best bet would be to have it recovered or replaced.
Old Aug 27, 2004 | 11:48 AM
80TexasC3's Avatar
80TexasC3
"Rodstoration &am p;quot; In Progres
I had a similar issue with my previous dash... use some CA "gap filling" glue to seal and create a smooth surface... then you will have to redye the entire dash if you want a perfect match. Is a lot of work but it works.
Old Aug 27, 2004 | 11:51 AM
76REDSTINGER's Avatar
76REDSTINGER
Default kind of bubba.....but
you could cover it w/ some type of emblem
or rectangular name plate........
kind of cheesy but if you found the right piece could be cool
R.
Old Aug 27, 2004 | 11:56 AM
Nick in OKC's Avatar
Nick in OKC
Default There are vinyl repair places who might be able to do it
The problem is that I have seen mixed results, sometimes looking good and sometimes still visible. Hopefully, a good shop would be able to fill it in fairly well. Matching color is often problematic, too. It is worth a try before you go to the trouble of replacing the dash.
Old Aug 27, 2004 | 12:03 PM
kermit1654's Avatar
kermit1654
Thanks! Whats brand name of "gap filling" glue you used?
Old Aug 27, 2004 | 12:05 PM
AGVI's Avatar
AGVI
Canadian Events Coordinator
Don't replace it if it is in otherwise good overall condition.
Fix it or have it fixed by a professional.
Les
Old Aug 27, 2004 | 09:01 PM
vttedrm's Avatar
vttedrm
Then it will look like this
[IMG][/IMG]
Old Sep 4, 2004 | 03:59 PM
kermit1654's Avatar
kermit1654
Ttt
Old Sep 5, 2004 | 12:03 AM
68/70Vette's Avatar
68/70Vette
What is "CA" glue? If CA glue is it's only name, where can I buy or order it? Thanks. I'd like to try it.
Old Sep 5, 2004 | 01:44 PM
kermit1654's Avatar
kermit1654
CA stands for Cyanoacrylate glue [tradenames: Super glue, Hot Stuff, Zap, Crazy Glue, etc.] Model buiders use this glue a lot. You probably won't find the gap filling type anywhere but a hobbie shop. To find it online, just type "CA gap filling glue" in google and you'll find a lot of sites selling it.
To How do I fix this Dash??
