Vinegar Like An Acid
Old Aug 27, 2004 | 07:21 PM
MEGALADON's Avatar
MEGALADON
From: WAY DEEP INSIDE AMERICO,YES YOU LIVE HERE TO!! TX
Default Vinegar Like An Acid
I am rebuilding my calipers, had rust on the inside of them
but not on the sleeves. So all this talk of vinegar works
great stuff had me curious So I put in the calipers
plit in 2 into a oil change pan 50/50 water/vinegar. 2 minutes
after that it started to bubble like it was in a acid bath. I put
them in last nite and their still boiling turning white
as we speak think i'll leave them for another day
and see what happen's. So thanks to all
Old Aug 27, 2004 | 07:31 PM
Boofers's Avatar
Boofers
Vinegar is not like an acid, it is an acid. Glad to hear of your success!
Next time soak your rusty parts in a bath of Coca-Cola, prolly would work just as well as vinegar.
Old Aug 27, 2004 | 07:36 PM
MEGALADON's Avatar
MEGALADON
Anyone want to post pic's if I take some
Old Aug 27, 2004 | 07:45 PM
olouieo's Avatar
olouieo
I will, just email them to olouieo@lycos.com.
Old Aug 27, 2004 | 08:27 PM
Paul L's Avatar
Paul L
I think you are asking for trouble, big time. Acid bath and brake piston seals do not mix. Get some professional help. This is not a repair that should be fooled with. Even with a dilute acetic acid solution.
Old Aug 27, 2004 | 09:54 PM
RFJohnston's Avatar
RFJohnston
From: Russellville, Kentucky 1967 Sting Ray & 2001 C5
Old Aug 27, 2004 | 10:48 PM
Pedro'74's Avatar
Pedro'74
I was skeptical about this vinegar thing, but I'm now a believer. I tried it on the splash shields of the '74, and it worked great. It's slower than things like "Oxysolv", but does a better job. It seems like it releases/dissolves the rust, rather than chemically changing it, and it's not too agressive...
-Pedro
Old Aug 27, 2004 | 11:49 PM
lostpatrolman's Avatar
lostpatrolman
Paul, it seems like plenty of water would sufficiently wipe the vinigar off wouldnt it? Maybe sprinkle some milk on it to neutralize the acid??
Old Aug 28, 2004 | 06:08 AM
Twin_Turbo's Avatar
Twin_Turbo
water will neutralize the (weak) acid, it just dilludes it. It's acetic acid. No need to waste milk
Old Aug 28, 2004 | 08:32 AM
Avette4me's Avatar
Avette4me
Cruise-In VIII Veteran
I've used vinigear to clean the heater for the horses water tank for 20 years. Have had the same heat element for about 10 with no problems at all. Soak it over night, lose about 1/8" of crud, rinse and it looks nearly new and is ready to use.
Old Aug 28, 2004 | 09:25 AM
comp's Avatar
comp
baking soda
To Vinegar Like An Acid
