Another carb question
Old Aug 27, 2004 | 09:23 PM
Randexter's Avatar
Randexter
Default Another carb question
so i slaped on my spread bore holley and let her run for a while and she sounded fine but when i turned the car off i noticed that the secondaries began to fill up with gas, its not liked they got filled up to the top or anything but there was a noticably large amount. so my question is wheres the leak coming from? i know its somewhere above the secondary throtle plates but im also completely sure its not the boosters. i should also mention that the carb is a 4165 and its been modified with center hung floats and a metering block conversion was done on the secondaries, its the kind without the power valve or ajustment screws. i was thinking i might just replace the secondary metering block with a new type from proform does any one think this would solve my problem? any help would be greatly appreciated thanks
Old Aug 27, 2004 | 11:33 PM
comp's Avatar
comp
ttt
