Painting master cylinder??
Old Aug 29, 2004 | 07:24 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Default Painting master cylinder??
I know some guys have done this, but what type of prep and what kind of paint did you use?
Old Aug 29, 2004 | 07:37 AM
foundvettelifeisgood's Avatar
Fine wire brush and satin black rustoleum. Still looks great after a couple months.
Old Aug 29, 2004 | 07:46 AM
Jughead's Avatar
Jughead
St. Jude Donor '09
Thanks Jay, I just found this thread too. Sounds good except for the "baking" part. I can cook but I'm not good at "baking."
http://forums.corvetteforum.com/show...aster+cylinder
Old Aug 29, 2004 | 09:09 AM
rosslato's Avatar
rosslato
fantastic stuff. thanx
Old Aug 29, 2004 | 09:25 AM
ettev's Avatar
ettev
The correct finish for your 1970 would be a semi-gloss black finish. I used Eastwoods black paint for brake drums, etc. Or use black engine paint. You need something to be able to handle the occasional drop of brake fluid.
Old Aug 29, 2004 | 09:40 AM
marshrat99's Avatar
marshrat99
If you're not interested in a stock color, then your options are almost unlimited. I've done mine in hi-temp aluminum and added a coating of hi-temp clear. Looks great.
The usual sanding and a good soapy water cleaning to get rid of any oil is all that is required. Just don't get in a big hurry and let paint dry for a few days before handling.
Old Aug 29, 2004 | 09:55 AM
Jughead's Avatar
Jughead
St. Jude Donor '09
How does it hold up to brake fluid?
Old Aug 29, 2004 | 10:45 AM
427V8's Avatar
427V8
C6 the C5 of tomorrow
USe real automotive basecoat/clearcoat paint. Brake fluid won't attack it so bad, especially if you wipe off any spills quickly and will look great.
Old Aug 29, 2004 | 10:49 AM
Twin_Turbo's Avatar
Twin_Turbo
A wirebrush isn't the best method to clean the MC. I would remove it and sandblast it with AlOx, that will remove all the rust and provide some means of rust proofing (alox embedding), then do as Keith said. A real automotive 2 component paint (paint + catalyst) and maybe a clear coat will give the best result. The aerosol paints will not hold up as good as the 2 component paints. You could also have it powdercoated, the coating is available in almost any imaginable color.
Old Aug 29, 2004 | 11:08 AM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
I used POR15 black on mine and it has been on mine for about 3 years of brake fluid changes and it still looks good.
Old Aug 31, 2004 | 11:22 AM
NHvette's Avatar
NHvette
I'm with Eddie - I wouldn't use any paint - use the POR-15 to be brake-fluid proof.
To Painting master cylinder??
