'69 Speedometer Not Working
Old Sep 1, 2004 | 02:43 PM
ZOWE6's Avatar
ZOWE6
Default '69 Speedometer Not Working
Hi,
The speedomter stopped working on my '69 a few months ago. As I understand it, either the cable is bad or the gear in the tranny needs replaced. Is this correct? Does anyone have advice on how best to determine the exact cause?
Prior to the failure, the speedometer needle used to bounce quite a bit at lower speeds.
Jeff
Old Sep 1, 2004 | 03:51 PM
Chuck Gongloff's Avatar
Chuck Gongloff
Active Streak: 90 Days
Could also be the speedo "head". Disconnect the cable from the trans. Put the end in your drill and spin the drill. Don't remember clockwise vs. counterclockwise.
If the speedo works, the problem is in the trans gear.
If the speedo doesn't work, it could be the cable or the speedo head.
Disconnect the speedo cable from the back of the speedometer, spin it and see if it's broken, or one of the squared ends is rounded off. Hope this helps. Chuck
Old Sep 1, 2004 | 04:25 PM
ZOWE6's Avatar
ZOWE6
Thanks Chuck. Should I spin the drill clockwise?
Old Sep 1, 2004 | 05:59 PM
JOliver's Avatar
JOliver
Spin it counterclock wise.If it turns out to be the speedo email me I can help with the rebuild.
Jason
VetteInstruments@aol.com
Old Sep 2, 2004 | 01:28 PM
ZOWE6's Avatar
ZOWE6
Thanks Jason!
To '69 Speedometer Not Working
