HEI module with built-in Rev Limiter
Old Sep 3, 2004 | 06:05 AM
American Boy's Avatar
American Boy
Default HEI module with built-in Rev Limiter
Anybody run one of those and have the part number? I want to add a safety since I change from auto to manual and do some drag race. The module would be cheaper than a big module like a MSD-6AL.
Stephan
Old Sep 3, 2004 | 09:39 AM
stingr69's Avatar
stingr69
Crane sells a nice add-on piece. HI-6 or what ever they call it now. It has a multispark CD ingnition box that has a built in adjustable rev control. You set the RPM level with a little screwdriver. You can use a magnetic trigger or it can even trigger it using points if you feel so inclined. I run one on my other car. The box is mounted under the dash so everything still looks stock under the hood.
-Mark.
