I have the original heads (L48) on the car at the moment along with headers, intake, cam and chambered exhaust (going in soon). And since Lars worked his magic on the carb and dist., the car runs great.
I want to replace the heads with the Sportsman II heads (200cc) without changing to flat top pistons. I think the compression is around 8.5 form the factory.
Can just slapping on the new heads hurt anything? Bottom end is stock. I am going to do a compression test before changing heads.
Will just changing to good quality head help much or do I have to swap pistons as well?
Depending on your long term goals they will be fine esp if you get 64cc version although that runner size might be a bit large and hurt your low end torq. If you are shooting for 400hp or close you might want to look at the L98 alum vette heads, can be had cheap on e-bay and will also bump your compression even more since they are 58cc heads (what are used on the ZZ4 crate motor as a matter of fact).
So Fevre, what you're saying is that he could run the heads for now without any problems.
I don't mean to hijack the thread, but I was considering getting the Dart Iron Eagle 64cc heads, but don't think I'll be changing the pistons yet.
I have ran some 64 cc cnc'd Trickflow heads on a 350 LM1 crate eng, pretty much a L48, with pretty good results using a 224/232 duration roller cam. As long as your low end is good and you aren't going to rev it past 5500 or so (I have taken mine to 6300 ) you should be fine. Cast parts (crank/pistons) like what is used in the L48 and LM1 are not the best for high performance or long duration but if treated with some respect can last a good while.
I am running HE260H, low end could be better but otherwise happy with it.
I am worried about the stock bottom end. It's the original block. I shift at around 5300 rpm when floored without any problems all the time....no issues there.
And yes these are 64cc heads.
I also have a 400 block machined and ready to go with some light weight Al piston, but if I am happy with the 350 I will not build it at all. My target is to get around 350 hp out of the old 350 without pulling the block.
A guy here has an L48 with Headers, non stock exhaust & a few other small mods (not sure if the cam is original). He recently changed the stock heads for Sportsman II's, keeping the original pistons, & loves the results. He's well impressed. It really pulls well from the low mid-range & just wants to keep going right up to the top end, sounds better, picks up better, etc, etc. He's very happy with the results.
I also have the sportsman 2 heads and like said above pulls hard mid to top end with 3 different motors ive run them with,from stock piston motor,to forged11.1 motor to the flat top hyper. i have now.
Hi Ganey,
What are the advantages of a rebore? If the bores have low wear then wouldn't a light hone be better ie. saves the block for a rebore at a later date (extending service life), less work & a lot cheaper?
Hi Ganey,
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Slap those Sportsmans on they will really wake the 'ol L48 up, while your at it you can upgrade to Harland Sharp full roller rockers, a CC 282 solid cam and some cool looking polished aluminum valve covers like the ones below
Thanks guys
A swap to 64cc heads should give you about 9.5:1 over the current 8.5:1. 9.5:1 is still well within what cast iron heads can and do run. I'm going to differ from others and throw out another option to consider: flat tops w/ reliefs and mildly pocket port the existing heads - they actually do flow pretty well and can easily flow better. But I'm sure those alum heads will slap on just fine and work well. If you are not after high RPMs your bottom end is fine but may benefit from an overhaul w/ all the other changes being thrown at it.
Thanks for the info guys. I was just trying to avoid pulling the engine. If I can slap on new heads and make respectable power (around 350), then I will not swap the pistons.
My concern is just that the crank and rods might not hold up. But again, I won't know until I try. The only draw back is that if I damage the block, there goes the original number matching car.
