Molding Bumpers
Old Sep 4, 2004 | 03:21 PM
Silver00V6Camaro's Avatar
Silver00V6Camaro
Default Molding Bumpers
Any of you out there that have molded the rear or front bumper in what did you do because of the bumper being urethane and the car fiberglass. What did you use to mold the bumpers in. Did you use bondo or fiberglass or a panel bond adhesive. Any advice is appriciated
Old Sep 4, 2004 | 10:13 PM
doopsvette's Avatar
doopsvette
i just bought front and rear pieces off a fella here in australia who used new ends to make fibreglass moulds. the new end are fibregalss and dont ripple or buckle and once their bonded in place there are no joins and they look great
Old Sep 5, 2004 | 12:46 PM
Silver00V6Camaro
I have a original 80 rear bumper that is ureathane and I am wanting to know for the people that have molded the ureathane bumpers in how did mold the ureathane to the fiberglass
Old Sep 5, 2004 | 02:08 PM
Nick in OKC's Avatar
Nick in OKC
Default A friend of mine molded in fiberglass bumpers
It looked great on his '77. I think he got the bumpers from Ecklers, but that was about 25 years ago. It seems to me molding urethane bumpers to a fiberglass body would be problematic. I would think the flexibility of the bumpers would eventually result in cracking around the joints. I an certainly no expert, however, and I am curious to know if this has been done successfully.
Old Sep 5, 2004 | 02:44 PM
AGVI's Avatar
AGVI
Canadian Events Coordinator
Fiberglass to fiberglass seems to be the only way to go.
Old Sep 5, 2004 | 02:47 PM
rrent's Avatar
rrent
I've seen a couple of cars here in the past -- but I think all had aftermarket fiberglass bumpers. You might be able to search - seems the cars were being painted at the time -- there was one young lady who had a redone car with leopard print (paint) at the vents -- she had molded in bumpers -- her car was even in a magazine -- but I don't remember her name.
Old Sep 5, 2004 | 04:10 PM
Rockn-Roll's Avatar
Rockn-Roll
Sounds like you can just attach the bumper as normal and fill in the crack with some Bondo - Fiberglass Resin. If you use all of the bolts to hold the bumper on then the bondo should hold without cracking. The resin doesn't stick to the urethane all that well, but unless someone sits on your bumper then it should be OK, especially if you apply like 10 clear coat coats...that stuff is almost as tough as iron.
To Molding Bumpers
