MSD Distributor
Old Sep 5, 2004 | 12:18 PM
Z QQH 6's Avatar
Z QQH 6
Senior Member
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Default MSD Distributor
Has anyone hooked up an MDS distributor?
My 69 BB 435 was bought with a Mallory dual point and its time for it to go. The dual point is using the black and yellow wires for ignition. I have the TI pink/gray wire taped out of the way. Which wires do I use?
Z QQH 6
Old Sep 5, 2004 | 10:54 PM
MrForce's Avatar
MrForce
St. Jude Donor '11, '14
You will most likely need an MSD ignition box or similar CD type amplifier box.
Old Sep 6, 2004 | 09:39 AM
Bobchad's Avatar
Bobchad
Their catalogue and web site it pretty clear which of their distributors require the box and which doesn't. I replaced the HEI in my 77 and it didn't require the box. Pull the old one out, replace the wires exactly as they came off the old distributor and I was up and running. I changed mine because mine needed to be rebuilt and I wanted the ease of changing the advance curve that this distributor seemed to offer.
Old Sep 6, 2004 | 01:31 PM
Z QQH 6's Avatar
Z QQH 6
Senior Member
Cruise-In V Veteran
I was wondering if one set of wires is prefered over the other. Which is used if I was replacing TI distributor? Thats what it was built with from GM. Guess I'll confer with MSD. Yes it will require the spark box.
Z QQH 6
Old Sep 6, 2004 | 01:49 PM
Solid LT1's Avatar
Solid LT1
You should FIX! your car correctly if it is a "true" 435HP Vette. The T.I. ignition is a good system as long as "Bubba" hasn't destroyed it (it can be properly rebuilt by knowledgeable people.). Here is a link to the #1 T.I. guy in the world, give Dave a Email and fix your car right, don't "Bubba" it again! Here's the link: http://www.tispecialty.com/index.html
Old Sep 6, 2004 | 02:04 PM
Z QQH 6's Avatar
Z QQH 6
Senior Member
Cruise-In V Veteran
I know of these people and agree.
My post indicates that I bought it with a Mallory dual point in it so this should give the clue. I have a 435 3x2 in it but theres way to much to put back in it.
Z QQH 6
To MSD Distributor
