Lets talk about Crankcase evacuation
Old Sep 6, 2004 | 02:49 PM
Steve Straus's Avatar
Steve Straus
Default Lets talk about Crankcase evacuation
This thread was started so that we didn't hijack another thread. You can read the previous posts at: http://forums.corvetteforum.com/showthread.php?t=898350
My engine has been smoking and leaking oil like crazy since I've owned it, and I'm wondering if I need more than just the standard PCV system. I ran a leakdown and compression test today, and I'm looking good.
Olivier, can you post some pictures of your crankcase evac system? How did you weld the tubes into the collectors on the sidepipes without having them show? Did you do it yourself or did you have it done?
BTW, I can't believe those pumps are $360, that's insane. I'd like some pictures of how those mount if you have any. The drive system for them looked interested, it looks like a piece that sticks out and drives it from the harmonic balancer.
Old Sep 6, 2004 | 02:53 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
I'm going to look up the pics.. I didn't do the install myself because it involves welding.. I had Van Steel weld the tubes into the pipes.. They charged my like $40 to weld the tubes into the pipes and for the hose to connect the tube on the pipes to the breathers..
I'll post pics as soon as I find them..
Old Sep 6, 2004 | 02:59 PM
GrandSportC3
Here are the pics of the system..
BTW - my total cost was less than $100 including the labor to weld the tubes into the headers.. The system is not visible unless you look under the pipes...
Old Sep 6, 2004 | 03:13 PM
Steve Straus
That's pretty clean. I think I'm going to go with the pump though. Call me crazy, but I'm going to avoid any welding to my jet-hotted pipes.
I need to read up on the pump evac system. I'm curious where it puts the oil vapor from the crank case. I'm assuming it feeds it back to the pcv port on the carb somehow.
Old Sep 6, 2004 | 03:32 PM
Steve Straus
I wonder if I can use an OEM smog pump as a vaccuum pump? Not quite as trick looking, but if it works....
Old Sep 6, 2004 | 03:39 PM
tshort's Avatar
tshort
CI 7-8 Veteran
Steve,
I think the pump pumps the oil to a container. You then have to drain the container every once in a while.
Old Sep 6, 2004 | 03:42 PM
gdh's Avatar
gdh
I like Olivier's setup over the pump, just one less thing to worry about and it looks very clean.
Old Sep 6, 2004 | 05:57 PM
Twin_Turbo's Avatar
Twin_Turbo
I've had a heder evac system for a long time, always worked perfectly, here's the same thing on my new buildup (I will remove the cutouts, will weld a bung for the valves to screw in on the new system), it's the thing with the orangle plug on it:
Old Sep 6, 2004 | 06:52 PM
GrandSportC3
Originally Posted by tshort
Steve,
That's correct!! It gets pumped into a breathable container...
Old Sep 6, 2004 | 06:53 PM
GrandSportC3
Don't know if the smog pump would work...
Old Sep 6, 2004 | 06:57 PM
GrandSportC3
Don't forget that you need to run without mufflers for the system to work.. As soon as there is backpressure - it won't work..
Old Sep 6, 2004 | 08:29 PM
LemansBlue68's Avatar
LemansBlue68
Unless you've got an all out race motor I don't see why an evacuation system would be necessary. Sounds like you're band-aiding another problem. Are you seeing any signs of excessive oil being blown out through either the PCV lines or where the fresh air tube connects to the air cleaner. I've seen leak down/compression tests be completely misleading when it comes to the actual blow-by levels that the engine produces while running. Just a reminder to be sure to cover all the basics before moving on to the more compicated (and expensive) solutions.
Old Sep 6, 2004 | 09:31 PM
Steve Straus
Even with spiral baffles?
Old Sep 6, 2004 | 09:36 PM
GrandSportC3
During the years - I had 3 different street/race crate engines from 3 different builders and all of them would consume oil.. I always ran a PCV system and all of the engines would suck lots of oil into the engine.. The current engine is the only engine on which I installed a evacuation system and it eliminated 90% of the oil consumption and the remaining 10% is very likely exiting unburned throught the exhaust by design (the vacuum of the exhaust sucks it out).. The problem is that the rings never seated perfectly without the evac. system because of the pressure that was building up.. The smoking/oli consumption stopped shortly after I installed the system... I don't know why it was working that good for me.. The only thing that I know is that it worked for me...
Old Sep 6, 2004 | 09:39 PM
GrandSportC3
It might worked with uncapped spiral baffles, but it won't work with capped baffles... Capped baffles create too much backpressure...
Old Sep 7, 2004 | 12:54 AM
Steve Straus
I know I brought this up already, but does anyone know how much vacuum a smog pump pulls? I've been reading that a some racers have hooked up smog pumps to a breather to evacuate the crankcase. If I hooked the outlet to a moroso evac container that might work for me until I can afford to go with the real mccoy.
Lemans: Yes, I have oil leaking out of the dipstick. I've tried everything at this point. I have a more radical cam in this engine than any I've had in the past. I've never had problems like this before, so I'm trying something new.
Old Sep 7, 2004 | 01:15 AM
EDDIEJ82's Avatar
EDDIEJ82
You know I'm probably wrong on this but doesn't a smog pump... pump air and not suck it.
If you could get it to turn the opposite way it might suck.... but then where would the oil that it sucked go? out the intake wherever that is? They only have one pipe coming from them.
To Lets talk about Crankcase evacuation
Old Sep 7, 2004 | 01:21 AM
Steve Straus
I've found some that have an inlet and an outlet.
This system is a little more affordable than the Moroso though...
http://www.candsspecialties.com/store/html/pumppan.html
Old Sep 7, 2004 | 01:28 AM
EDDIEJ82's Avatar
EDDIEJ82
Whew... thats pricey, I see why you are looking into smog pumps now
Old Sep 7, 2004 | 08:44 AM
norvalwilhelm's Avatar
norvalwilhelm
What's so wrong with a PCV valve in one head and in the other a line running to the air cleaner element?? That is the standard hookup and it works. I never see oil vapors or leaking over the valve covers.
Running open side pipes is just too loud, I value my hearing and don't want to annoy everyone within a mile of me.
