Power Window Spring
Old Sep 7, 2004 | 09:24 AM
dougbn's Avatar
dougbn
Cruising
Default Power Window Spring
Does anyone have experiance replacing the power window regulator spring? Cannot see how to access it. 74 coupe
Dougbn
Old Sep 7, 2004 | 10:01 AM
Ak. Mal's Avatar
Ak. Mal
From: Kansas City, MO ...I'd like to go fishing and catch a fishstick. That'd be convenient. - Mitch Hedberg
I'll be waiting for this answer since I have to do this also.
Old Sep 7, 2004 | 10:34 AM
stingray4me's Avatar
stingray4me
I got a used regulator off ebay, here is the web page I made up. http://members.***.net/stingray4me/regulator.htm
Old Sep 7, 2004 | 10:39 AM
ImBatman's Avatar
ImBatman
I am in the middle of doing this on my '71. You will have to take the entiire regulator assembly out of the door. Remove the power window motor and unwind the tension off of the spring. Be very careful when doing this job. It looks simple and it really is. However, it is also very dangerous. Check out stingray4me's web site. It gives you some good visuals and advice on removing and reinstalling the reg safely.
Wade
Old Sep 7, 2004 | 01:34 PM
LABulldog's Avatar
LABulldog
I recently did this on the passenger side of my '80. My spring had broken, so in-turn I had to install a new spring. I assume that your spring has broken also. I used stingray4me's web page and it really helped. The only problem I had (besides getting the damn glass out of the door to remove the regulator assembly) was installing the spring. I ended up standing on my regulator (I don't have a vise) and grabbing the inner part of the spring with a pair of vice-grips and slowly twisting the spring until it went into the slot on the regulator rivet. Do it nice and slow and it will work. Beware that there is a lot of tension in the spring. Good luck!
Old Sep 7, 2004 | 02:39 PM
dougbn's Avatar
dougbn
Cruising
Thanks alot for the info...sounds like I have to disassemble the complete door. Where you have already done this do you have any pointers on that? I can't even see where the inner metal piece/cover seperates.
Doug
dougbn's Avatar
dougbn
Cruising
Doug
Old Sep 7, 2004 | 07:29 PM
LABulldog's Avatar
LABulldog
Well Doug, I don't know what the differences are between the 74 and the 80 but to remove the door panels, I had to remove the arm rest (three screws), the door handle cover (1 screw), side mirror adjustment (2 screws + a recessed allen head screw in the adjustment lever), 2 screws in the lower part of the panel below the arm rest (one up front and one in the back), and one up in the upper rear corner of the door.
Removing the panel will give you access to the inner workings of the door. I had to pull the window out (that was a bitch) to release the parts that raise the window. The regulator was bolted on with 3 nuts. My regulator came out through a whole in the inner door section. Reverse the procedure to put everything back. I did not replace the rivet on my regulator. Mine was in good shape. Don't know exactly how to remove it if you have to do that. Good Luck.
Old Sep 9, 2004 | 10:50 PM
dougbn's Avatar
dougbn
Cruising
Default Spring
Thanks for your help...I am learning that this problem and the emergency brake issues are killers.
Thanks again for your help.
Doug
To Power Window Spring
