Possible bad trans mount?
Old Sep 7, 2004 | 10:13 AM
jeromeunderwood's Avatar
jeromeunderwood
Default Possible bad trans mount?
Hey guys, on a 82 I have a bad jerk in the rear end when i put it in drive... I plan to get under the car and look really good to find the prob but i thought one of you have had this problem before. I replaced the diff. mount bushing so I know thats not the prob. I bet it is the trans mount. And all the cv joints are in good shape.
Old Sep 7, 2004 | 10:20 AM
nhlgopens's Avatar
nhlgopens
Open hood. Have someone sit it in (running of course) with foot on brake. Have them put in gear and give a little gas. You should be able to see the engine/trans torque. I had this same problem on a different vehicle. The mount fixed it. I also suggest going with the poly mount = usually around $60.
Old Sep 7, 2004 | 01:12 PM
MILO's Avatar
MILO
Check the rear pinion snubber. I just replaced mine this past weekend and it came out in four pieces.
To Possible bad trans mount?
