1980 Corvette - electrical problem?
Old Sep 7, 2004 | 01:10 PM
ghood's Avatar
ghood
5th Gear
Default 1980 Corvette - electrical problem?
I am having problems with my 1980 L82. After approx 1/2 hour of driving the car will lose all power and shut down. The power becomes so weak that I am not able to even listen to the radio. I must wait approx 1 hour and then I am able to jump start the car. This has happened twice in the past week. I checked the alternator but it was fine. I replaced the battery but same problem occurred. I am completely lost. I don't know what this could be. Any thoughts/help?
Thanks,
GHOOD
Old Sep 7, 2004 | 02:38 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
How did you check the alternator? Unless I miss my guess, you have a bad alternator. It's not charging the battery.
Old Sep 7, 2004 | 04:22 PM
80TexasC3's Avatar
80TexasC3
"Rodstoration &am p;quot; In Progres
I agree with rechecking the alternator... also should check your ground...
Old Sep 8, 2004 | 12:38 PM
ghood's Avatar
ghood
5th Gear
Default Checked the alternator
I took the alternator out of the car and had it tested at 2 different locations. Both of the folks that tested the alternator indicated that there was nothing wrong with the alternator. If it is a ground problem, any ideas on how to go about finding it?
Old Sep 8, 2004 | 12:57 PM
Ak. Mal's Avatar
Ak. Mal
From: Kansas City, MO ...I'd like to go fishing and catch a fishstick. That'd be convenient. - Mitch Hedberg
Get yourself a test light and a multi-meter. Then, just start testing the major grounds. If you get a weak signal, remove them and clean them up. Sorry to say, you are just going to have to work your way through your car. No easy answer for this one.
To 1980 Corvette - electrical problem?
