I need to remove my steering column cover and levers. Something broke/came loose inside my dimmer lever mechanism. Now the lever moves loosely back and forth and my headlights wont come on now dim or bright. How do I disassemble the cover and levers? It looks like I need to remove the levers before I can get the cover off? I have a 80 with Tilt/tele.
I dont believe the lever is broke because it still moves back and forth, but it does feel like its not going all the way back to its original position. Thinking is the switch or some part thereof. How much of the steering column has to be taken apart to check this?
