It might be cheaper and definately easier to just fix the vacuum system.
Disagree completely. Really depends on what parts need to be replaced from the vacuum system, but I did this entire upgrade with parts from the salvage yard. I wrote a tech story on this upgrade doing it on a budget and it will be published in Corvette Enthusiasts magazine out in November.
I would need to look at my story again, but I kept track of everything, wire, tape, wire connectors, etc. I think all told it was done for just under $300. Last time I checked one Actuator will cost you $100. This system is also flawless, less troublesome and best of all you can now run a real cam as you don't need as much vacuum to run all those vacuum operated systems. Yaa Hoo
From: WAY DEEP INSIDE AMERICO,YES YOU LIVE HERE TO!! TX
69MYWAY is a forum member here
he created the set up for no vaccum headlights.
I have his kit, and so does GROOVYJAY. this is
10 times better than vaccum
Easy there, killer! I said it MIGHT be cheaper. Last time I checked, it cost me $40 bucks total for a used vacuum relay and some new seals and mine works like a new system. As far as the cam is concerned, mine is stock so you got me there.
Aftershark, is that Novermber as in actually published in November, or the November issue, which is probably out now?
I've been looking around, and you can get a 75lb 4" stroke linear actuator for just $125. Seems like you could fabricated a simple lever system to tie to two sides together. That's just $25 more than replacing both vacuum relays, not to forget the entire rest of the system that could go bad. You would have to work out the electrical system a little though.
-Chris
What I meant was if your vacuum operated headlight system is at a loss then I would go electric. You can spend a lot of weekends and nights tracing down problems.
If your going to go with an electric system get the one from 69myway. I guess you could link them together with a single rod and use one actuator, but why bother if someone else has a kit figured out. It looks awesome installed also. I blacked everything out and it looks O.E.
The story should be out in the January cover issue of Corvette Enthusiast. Which should be on the shelf in November.
I bought everything used, online like the motors and control module. Except for the wire, Weather pack Connectors, wire loom and items like that I got some of those items from summitt and other stuff from a local auto electric store. In this story I give several web sources where to find some of the bigger items for cheap.
Why? Because I have alot of custom things planned for my front end, and I need all the space I can get. Not to mention it'd be alot cheaper. For most, yeh a kit would be best.
WOW he said flawless when talking about electrical devices!
The Vacuum system is the model of simplicity. Lets see those motors in 30 years...
One of my projects is to come up with a decent looking LO RISE electrically operating setup, using later Camaro light bulbs, mounted further forward, and eliminating about 50% of the weight off the vacuum system....pull out thost brackets and lids and so forth, and all those steel braces, you got some weight there, guessing 50 lbs/side....which seems kinda stupid to me....
at any rate the opening/lift should be 1/2 of what the stock is...and so the lowered profile under the grill also....which would aid airflow...
Gene,
Now THAT seems like a cool idea.
But since I just rebuilt mine I doubt I'd do it
Yes I said flawless. Everything eventually wears out, but comparing electric system to the old vacuum system. The vacuum system sucks. Every year for 5 years something would need to be traced down or fixed to bring them back up to speed. So far 4 months and counting with the electric conversion haven't missed a beat. Larger cam on the way and I won't have to worry about needing all that extra vacuum.
Also these electric motors and parts that 69myway used in these kits are proven pieces used on several applications from firebirds, c5, c4 saturns, and fieros.
About being able to use a "REAL Cam" and the origional vaccumn actuated wiper door and headlights. After reading many posts about how troublsome the vac. system was on these vettes, I was having nightmares about the headlights going up and down whenever they wanted in the middle of a dark night. I was wrong.
I've got a cam in a '68 327 that only pulls 9 inches of vaccumn at idle. The headlights and wiper door work perfect with the low vaccumn. Of course it had a frame off, and everything was rebuilt. I origionaly assumed I'd be needing a vaccumn pump and boutght one. Luckily I got to return it and use the funding for gasoline.
I might point out that you are doing an apples-to-oranges cost comparison. You can buy used vacuum actuators for $25-50 or so and used relay valves cheap too. If you buy those electric motors new GM you will not get them that cheap. Not saying electric is bad, just level the playing field.
