? about crate engine safty/emissions inspection
Old Sep 11, 2004 | 05:31 PM
SaltyNuts's Avatar
SaltyNuts
Default ? about crate engine safty/emissions inspection
Thanks to yalls help, I found that cars that are 25 years or older in Texas do not require emissions testing. Apparently, they don't even do a visual on emissions equipment like a smog pump and a catalytic converter. I talked to two different inspection places today and they indicated this was the case.
So the plan is to order a crate engine and say "to heck" with the catalytic converter/smog pump/whatever other equiptment might deal with emissions.
Question: if for whatever reason sometime in the future I have to put emission equiptment back on, can this be done to just about any engine? I just want to make sure I don't somehow order a crate engine that is totally incompatable with some emissions equipment that might be needed in the future as a result of a change in law or something else.
Thanks alot for any further help.
Old Sep 11, 2004 | 07:16 PM
SaltyNuts's Avatar
SaltyNuts
bump
Old Sep 11, 2004 | 10:02 PM
SaltyNuts's Avatar
SaltyNuts
Good question Retard. I'll let someone else help you, as I have no knowledge of engines....
Old Sep 11, 2004 | 10:34 PM
zwede's Avatar
zwede
Well, it's kind of a loaded question... what does "compatible mean"? As far as physically bolting on most of the stuff, I'm sure it can be done. You will have to modify some brackets here and there... for the smog pump you would need to drill holes in the header tubes etc.
But would you pass a sniffer? That's a different ball game. Now it depends on what kind of crate engine you got... how big of a cam, what kind of carb. How well is it tuned.
Old Sep 12, 2004 | 12:08 AM
Tom73's Avatar
Tom73
About the only thing that may not bolt back on is the EGR, depends upon if the intake manifold has previsions for one or not.
But that may allow it to pass a visual exam, but what about a sniffer or dyno test? Don't think it would pass then.
tom...
Old Sep 12, 2004 | 12:16 AM
SaltyNuts's Avatar
SaltyNuts
OK, guys, lets just say visual, forget the sniffers. About the only thing I might have to change on the engine is the manifold and some brackets? No block or head change?
Thanks so much.
Old Sep 12, 2004 | 12:23 AM
62fuelie's Avatar
62fuelie
Basically, anything that will bolt on one SBC will bolt onto another. There are some exceptions, due to the presence/absence of drilled/tapped holes, particluarily in the cylinder heads. The biggest issue you may come across is the use of Vortec heads on many GM crate engines. Some Vortec heads are dual pattern drilled to accept any intake manifold. Others are drilled only for the Vortec intake. None of these problems are insurmountable and the worst case scenario would probably be pulling the heads and taking them to a machine shop to get some extra bolt holes.
Old Sep 12, 2004 | 12:58 PM
SaltyNuts's Avatar
SaltyNuts
Got ya. Thanks so much.
I'll stay away from Vortec heads to avoid the issue.
To ? about crate engine safty/emissions inspection
