Need Alignment Specs 4 Performance Plus Suspension
Old Sep 11, 2004 | 10:36 PM
65LS6C4's Avatar
65LS6C4
Default Need Alignment Specs 4 Performance Plus Suspension
Can anyone assist with correct alignment specifications for a 68 C3 with a vette brakes & products performance plus suspension conversion
Old Sep 12, 2004 | 12:34 PM
AKRAY4PLAY's Avatar
AKRAY4PLAY
these are of their website. sorry, i can't remember what mine is set at. you could give them a call to verify. Brian
http://www.vbandp.com/instructions/h...ruct/align.htm
Old Sep 12, 2004 | 12:48 PM
zwede's Avatar
zwede
I would recommend the advanced street from the webpage above except I would go with a lsight amount of toe-in at front instead of 0. 1/32 toe in should do it. 0 toe makes the car a little jittery.
Old Sep 12, 2004 | 01:26 PM
burners's Avatar
burners
Cruise-In IV Veteran
Cruise-In V Veteran
Personally, I like 0 toe and I run -.25 degrees of camber and max positive caster in the front. On the rear I'm running 1/8" toe-in and -.5 degrees of camber. These are basically the Vette Brakes advanced street setup.
Old Sep 12, 2004 | 07:03 PM
65LS6C4's Avatar
65LS6C4
Thanks Guys - I appreciate you sharing your knowledge
To Need Alignment Specs 4 Performance Plus Suspension
