Replacement shifter question
Old Sep 15, 2004 | 11:35 PM
jacobsed's Avatar
jacobsed
Default Replacement shifter question
I purchased a used Borg Warner manual 4spd out of a 78. I'm in the middle of a body off restoration on my 79 nand am converting it to a manual. The original owner of the 78 hacked off the shifter to use on his overdrive tranny project. It appears all I need to do is press out a pin to remove the remaining shifter shaft. Can somebody link a complete replacement or make some recomendations that is economical but original looking?
Old Sep 16, 2004 | 12:42 AM
SHAKERATTLEROLL's Avatar
SHAKERATTLEROLL
There is only one shifter to get and that is HURST if it looks anything like a Mr Gasket design pass on it. They were junk.
Old Sep 17, 2004 | 10:35 AM
smoothsailing's Avatar
smoothsailing
Installed a Hurst. The ball height is better then the stock.
Old Sep 17, 2004 | 02:53 PM
herrelld's Avatar
herrelld
They are absolutely right, dump the stock and get the "real thing" Hurst. Got mine from Ecklers.
To Replacement shifter question
