Rochester 4MV
Old Sep 19, 2004 | 02:27 PM
hensen1954's Avatar
hensen1954
Default Rochester 4MV
Apart from jetting and maybe exterior attachments - can you use just about any 4MV of sensible age on a Vette ?????
Old Sep 19, 2004 | 11:43 PM
rtpilot's Avatar
rtpilot
My advice...after 35 years of changing 4MV's (15). I gave up. Just put on an Edelbrock 1806 Thunder & performer intake. My car has been original since new, but I just couldn't take it anymore. Now the car runs better than new.
Old Sep 20, 2004 | 12:56 AM
Shark Racer's Avatar
Shark Racer
I don't see why you couldn't use a 4MV on any year vette, assuming the intake will fit a spread-bore carb.
-Steve
Old Sep 20, 2004 | 05:03 AM
hensen1954's Avatar
hensen1954
Why did you have to keep changing them - worn out or what ????????
I am used to carbs lasting the life of the car with maybe a rebuild along the way. ??????????
Now more confused.
Chap here in UK has a 4MV off a 1982 Pontiac 305 which he's selling cheap........ shall I get it .???
Old Sep 20, 2004 | 05:29 AM
Larry B.'s Avatar
Larry B.
It won't work unless you have a computer controlled year vette.(80 -81) Even then there are several variations that affect the choke operation,and linkage.
Old Sep 20, 2004 | 06:36 AM
hensen1954's Avatar
hensen1954
But can I use it in a manual way - do choke myself ?????????
Old Sep 20, 2004 | 07:48 AM
Ganey's Avatar
Ganey
Now more confused.
No, you want a previous Q-J for performance & yes it will last. The electronic Q-J E4M needs a computer & was used from 80 in CA & 81 all states.
Get Doug Roe's Rochester Carbs book, mainly about the Q-J & you can know more about the Q-J than 99+% on any forum.
Old Sep 20, 2004 | 01:47 PM
lars's Avatar
lars
Hensen -
You can't use the '82 Q-Jet on a Vette. It requires an ECM, and cannot be operated "manually."
I have found that the 1975 - 1979 Chevy Q-Jets are about the most versatile. These are in cheap abundance, and they can easily be converted to electric choke by installing a 1980 choke cover. Drawback to this style Q-Jet is that the primary metering rods are only available in a few sizes.
The 1969-1974 Q-Jets are a bit more tuneable, and all rod sizes are available still. This vintage carb uses a divorced choke system that can only be converted to electric choke by using a manifold-mounted electric choke coil.
All Q-Jets, regardless of vintage, are about 750 cfm (with a few exceptions).
Old Sep 20, 2004 | 02:07 PM
hensen1954's Avatar
hensen1954
Thanks Lars - good info
To Rochester 4MV
