Do it yourself clock conversion
Old Sep 19, 2004 | 10:16 PM
vttedrm's Avatar
vttedrm
Default Do it yourself clock conversion
I'm going to attempt to convert my non-working clock via a rebuild kit from Corvette Central. Has anyone done this? Is there anything I should watch for? Thanks
Ken
Old Sep 19, 2004 | 10:25 PM
trw's Avatar
trw
I did it a couple of years ago. The hardest part is getting the clock out.
Instructions included with the kit. I would test before reinstalling.
Terry
Old Sep 19, 2004 | 11:56 PM
62fuelie's Avatar
62fuelie
Be careful not to break the instrument bezel removing the clock.
Old Sep 20, 2004 | 12:13 AM
vttedrm's Avatar
vttedrm
Thanks guys. One good thing, when I bought my vette, the seller also gave me a 2nd set of gauges (including a 2nd clock).
Old Sep 20, 2004 | 03:08 AM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
The only problem I had was getting the gear to match up with 'setting ' gear so I could set time. I had the problem with the height of the gears not matching up, so even though the clock ran fine I couldnt' set the time.
I just had to reset it again after blowing the fuse to the courtesy lights/clock and it works fine now. If I had just put it in w/out testing it though I'd be might mad at myself for not checking!
Old Sep 20, 2004 | 11:47 AM
SnoDrgn's Avatar
SnoDrgn
From: Swords Check/Saws Check/Clubs Check/Claws Check/Hatred Check/Anger Check/Murmaid Check/Murder Check
Cruise-In IV Veteran
Cruise-In VI Veteran
Mine worked great after I ran another ground wire from the frame to the cluster. Before that it would come and go. Also make sure when you put the hands back on that you don't put the hour hand at 12 and the minute hand at 6 otherwise your hours will always be halfway in between where they should be
Old Sep 20, 2004 | 01:10 PM
Lotus76's Avatar
Lotus76
Did mine last month, Its true the hardest part is mounting it in the dash, but I was replacing heater core while I was in that deep.
as long as your there change your lamps too
The clock rebuild was very easy.
Every time I look down and see that sweep second hand moving I feel it was well worth the time effort and expense.
And it keeps perfect time too...
John
Old Sep 20, 2004 | 10:00 PM
ClockworkOrange's Avatar
ClockworkOrange
Lotus is right.
I hated that two of the guages didn't work on my 73.
Did the conversion, just follow the instructions.
Looks complicated at first but half of the gears you just toss out, they are for a different model clock.
Fixed my oil pressure guage at th same time. Just needed oiling and a bit of grease, works excellent
Old Sep 20, 2004 | 11:26 PM
Wife'sVette's Avatar
Wife'sVette
Easy enough, but if you haven't ordered the rebuild yet, you could probably just clean your old one and it would work fine .... I took 2 broken ones and made one good one ........ works great ..... I also bought another working one for a backup overkill I guess .......Robert
To Do it yourself clock conversion
