Steering Box
Old Sep 20, 2004 | 09:25 AM
Richard Cooper's Avatar
Richard Cooper
Default Steering Box
I want to rebuild the steering box on my 1981, is this an easy job and do I need any special tools to do this job? Thanks in advance.
Old Sep 20, 2004 | 09:36 AM
Jack71's Avatar
Jack71
Rebuild your steering box?
I would
I think you're rowing into dark waters. Personally, I'd leave that to people with the special tools and use words like "spindle, worm bearing & sector gear".
Old Sep 20, 2004 | 10:15 AM
GTR1999's Avatar
GTR1999
Here's how I do them,
Gary
General Information
The boxes are divided into two groups, early and late. The early boxes,1963-1969early and Late 1969 to 1982. The early boxes have a finer spine worm shaft, use a different rag joint, have a cast cover. The later boxes, mid 1969 to 1982 use a different worm shaft with a flat milled into, a different rag joint with a flat, and an aluminum cover. Some of the May 1, 2004
1963-1982 Steering Box Rebuild Procedures
By very late boxes use a smaller cover bushing. I’m not sure when this started.
Tools and Materials Required
1. 0-30 inch pound Dial Torque Wrench
2. Large Channel Lock Slip Joint Pliers
3. Pitman arm puller or HD 2 jaw puller
4. Basic hand tools
5. Parts cleaner
6. Micrometer or 6” dial caliper
7. 1” Dial Indicator and magnetic base
8. Bushing drivers or large sockets
9. Mobil 1 red automotive synthetic grease
10. Putty knife
11. GM Overhaul manual
12. Rebuild kit
Rebuild Procedures
1. Remove the box from the car. The box is held in by a connection to the “rag joint”(coupling), the pitman arm to the control valve (Power steering) or center link (manual steering) and 3 bolts through the frame. It will be in pretty dirty shape.
2. Clean the heavy soils off the box once you get it out of the car.
3. Reference mark the pitman arm to the pitman shaft so you remember the orientation it is in when you re-assemble it.
4. Remove the pitman arm nut. This requires a 1-5/16” wrench or socket. I bought a $40 ¾” drive socket set to use and it works very easily. If you’re going to work on your corvette then buy the tools, you’ll use them for other projects I guarantee it.
5. Remove the pitman arm using a suitable puller. I have several types and found the $7 imported fixed 2-jaw puller works the best with an impact wrench. If you don’t have an impact wrench then a ½” drive breaker bar will do but you have to “work it” good. Ok, now you have the box in front of you cleaned, pitman arm off and ready to tear into it-Right??
6. Before taking it apart, get out that nice inch pound torque wrench you bought or borrowed. Mount the box in a sturdy bench vise by one of the mounting ears. Take a reading of the required torque going full CW and then CCW. Use the wrench lightly you don’t want to jerk it while you rotate it. Record it for future reference. It should start out low until you get about 2 full turns in and then you should feel it tightening up a bit. This is the on-center position with your wheel in the straight position. NOTE: I only use a dial inch pound torque wrench for this job. I can see the movement easily with this type of wrench. You can use a scale wrench but I never have so I can’t comment on using one. These wrenches run between $150-$250, so if you’re only going to use it once then see if you can borrow one. However, if you are going to rebuild your differential, as I outlined in another write-up, buy the wrench.
7. Now remove the three 9/16” head bolts from the cover. These are special lock type bolts, if you look at the threads they are not fully cut in a 60* v thread.
8. Don’t try and pry the cover off, it will only break. Use a long narrow screwdriver and unscrew the cover off the lash screw.
9. Put the cover aside but notice there is a bushing in it. I found that the later box covers had a cupped bushing in them with a smaller OD then the older box covers. The rebuild kits I have don’t have this “newer” bushing. The majority of the boxes have a straight through bushing with 1.250” OD. This bushing doesn’t wear as much as the two in the housing.
10. Remove the gasket under the cover
11. Use the large channel locks to loosen the lock nut on the rag joint end of the box. You don’t have to remove the lock nut now just back it off.
12. Center the pitman arm in the box by going to the end of travel and coming back approximately 2 full turns. In the muck that was once the box’s grease, you’ll see the pitman arm in the center of the worm nut. The worm nut looks like a rack gear.
13. Remove the Pitman shaft from the housing by pushing up from the bottom.
14. Now remove the worm adjusting nut and lock washer from the end of the box.
15. Slide out the worm assembly
16. Remove the pitman shaft seal from the bottom of the housing.
17. Use the putty knife to scrape out the old grease
18. Clean up all the parts in parts cleaner. If you don’t have a tank see if your local garage will clean them up for a small fee.
19. With everything clean lightly oil the pitman shaft and slide it back into the housing. Mount the housing horizontal in the bench vise and mount your 1” dial indicator against the end of the shaft at the end of the housing.
20. Move the shaft in/out and record the side play between the shaft and bushings, usually it’s around .007-. 010” The bushings in the kit will drop the side play down to around .005”. I like to get them between .001-. 002” maximum. I machine new bushing and hone them for this fit. However steering specialist like Corvette Steering may have under size bushing that you can hone yourself to get the tighter fit.
21. If I’m going to make a bushing set up then I do it at this stage. You will have to make that determination here.
22. To remove the old bushings I made a tool out off a couple of washers the same OD as the bushing-1.250” Bolt a couple of washer together and grind a flat on one side. You do this so you can get the “tool” inside the housing in between the bushings and flat against the bushing OD.
23. Use a long drift and hammer the old bushing out. Flip over the housing and drive out the other bushing.
24. Use the long drift to drive out the end plug and bearing from the housing.
25. Use a punch to drive out the bearing race from the adjusting nut and housing end.
26. The housing is now stripped of all the parts.
27. Now install the housing bushings, either the standard replacements, undersize, or custom made. I prefer the custom made ones, they can be fit the shaft after polishing it. I made a shaft up that is the size of the bushing ID and a shoulder the size of the OD. I can hammer or press them in without any distortion.
28. I use 660 bronze or oilite bronze for the custom bushings. Mostly 660 bronze, I cut a groove into the bushing after it is fit in the housing for grease to get down around the shaft. A rotary burr in a die grinder or Dremel tool works great for this. When installing the bushings they will compress slightly. I make the ID about .001” oversize then use a brake cylinder hone to fit the shaft for the fit I want.
29. At this point you can clean up the housing as needed for your purpose. Some were natural cast finish, others were painted black. I clean the housing and paint it.(I’m not a “numbers” guy so painting isn’t a problem)
30. I use POR15 Metal Ready and keep it wet on the housing, pitman arm, and adjusting nut for 20-30 minutes. Then wash it in water and dry. It should come out with a white film on it.
31. I then paint it with POR15 black and let dry.
32. When the POR15 is tacky I top coat it with cast blast and finally a couple of coats of Eastwoods satin clear.
33. I polish the aluminum cover on the late 69-82’s to bright shiny finish and topcoat with satin clear. The early boxes have a cast cover that I just finish the same as the housing.
34. To remove the bushing from the cover I use the Dremel and burr again to slot the old bushing and collapse it with a chisel. I’ve tired cape and pointed chisels but they didn’t work too well. Use emery cloth to clean up any burr you leave in the cover ID.
35. Remove the ball guide clamp from the worm nut and remove the ball guides. These are split so watch out for the ***** inside.
36. Unscrew the worm shaft from the worm ball nut. Catch the ***** as you do this. There should be a total of 54 ***** in the assembly. If you are using a rebuild kit then you’ll have new *****. If you are just cleaning and sealing the box then wash the ***** for reuse.
37. Wash the worm nut and shaft. Inspect for any pitting, rust, anything that might cause a problem. Most times it will be fine to reuse the parts. Inspect the worm nut teeth for and heavy pitting or wear. It ok if they have a pattern as long as it’s not a groove.
Assembly of the Steering Box
1. Install the new bushing in the cover and put it aside.
2. You should have the new bushings in the housing, if not install them now.
3. Count out 27 ***** and place them in two groups. I use a spray can cover to hold them from rolling all over the place.
4. Grease the ID of the worm nut and lightly the worm shaft. You want to do this in a very clean area so you don’t pick up any dirt in the grease and wreck your rebuild.
5. Lay the ball guide on a clean, flat surface and lightly grease the guides. Add 8-9 ***** to the guides and place the second half of the guide on top to hold the ***** in place. Remove the ***** from each grouping you have so you don’t get confused where they came from.
6. The worm nut goes into the housing in a specific direction. The teeth of the nut are tapered so the pitman shaft can be adjusted. Looking at the worm nut teeth, the side with the widest part of the teeth should be pointing to the bottom of the housing. The pitman shaft rack is tapered to tighten as it travels down into the worm nut teeth. If you get this mixed up you will not be able to adjust the box or fully assemble it.
7. The worm nut has 2 circuits for the ***** to ride in. I start installing the new ***** in one circuit then do the second. You have to hold the shaft up as you first start the ***** in the nut. I use a small pocket screwdriver to punch them down and around the shaft in the nut. When you have all the ***** from the first group in place install the loaded ball guide into the holes. It should fit easily and all the way down. Now do the same to the second circuit and install the clamp and screws. It should rotate nice and smooth without any backlash or ***** falling out. If you did this correct the 54 ***** will be in place and the worm assembly is ready for installation in the housing.
8. Install a new bearing race in the housing plug end. Be sure the radius side of the race is facing the inside of the housing so the bearing with mate with it. I use a deep socket or bushing drive to tap the race in place.
9. Use some Permatex #2 on the plug counterbore. Use only a light coating, you don’t want it pushed inside the housing.
10. Place the new plug in the counterbore and hammer tap it into the bore. Wipe away any excess sealant.
11. Deform the plug to expand it into the counterbore to seal it in place. I use the ball end of a heavy ball peen hammer to do this. If you have a press and radius end shaft you can use that too.
12. Install new grease seal in the housing for the pitman shaft. Lightly grease the rubber seal.
13. Grease a new ball bearing and place it on the end of the worm shaft. This is just slip fit. Face the ***** toward the race you just installed. Place some grease on the race but not too much as it will not compress and it will push back the shaft when you install it.
14. Slide the worm assembly into the housing and seat the bearing.
15. Grease the second bearing and place it on the open end of the worm shaft.
16. Install a new bearing race in the adjusting nut cover, again the race must face the bearing on the shaft.
17. Install new grease seal in the nut. Grease the rubber seal so it doesn’t get damaged when installing the nut over the shaft.
18. Use some #2 on the adjusting nut threads and screw the nut into the housing over the shaft.
19. Snug the nut and move the shaft by hand from lock to lock. There should be no backlash, if there is check the bearing in the plug end to see if it moved.
20. Use the torque wrench to check the rotational drag moving the shaft. I use an old rag joint that I welded a ¾” nut to. I use a socket on the wrench to check the drag for the earlier boxes a 12-pt 11/16 socket will work.
21. Tighten the nut until you have 3-4 inch pounds and you will feel a slight drag on the bearings. This is the pre-load for the end bearings.
22. Install the lock nut and tighten it good, I don’t use a torque wrench just make it tight.
23. Recheck the drag to be sure it didn’t go beyond the 3-4 inch pounds you just set.
24. I add grease around the worm nut and housing now. Lightly grease the bushings too.
25. Check the gap of the lash screw between the screw bottom and the slot. It should be less then .002” Most times the gap is about .005-. 007” If using a rebuild kit there are shims to tighten this gap. You should be able to get it under .002”. I use a surface grinder to fit the gap to .001-. 0015” Use feeler gauges or shim stock to check the gap. I tighten the nut on the screw when checking the gap to get an accurate measurement. Try the feeler gauge in with the nut loose vs. snug and you’ll see what I mean.
26. Move the worm nut to the center of travel and slide the pitman shaft into the housing. The center of the shaft rack teeth must be on center of the worm nut teeth. There are not many teeth so don’t be too concerned, you’ll see what I’m talking about when you look at it.
27. Now finish greasing the box. You need to leave room for expansion when hot so don’t overfill it. 11 oz is the maximum amount of grease to use. I rotate the shaft full travel to check that it moves freely and add grease behind the gaps. With the cover off the shaft will slide down into the worm nut so you may have to hold it up when rotating it.
28. Use some #2 on the cover gasket and seal it to the housing.
29. Screw the cover on the lash screw until the cover seats in the housing bore, watch you don’t roll over the cover gasket.
30. Install the three 9/16” head bolts in the cover and tighten. You may have to bring the lash screw up to compensate for tightening the three screws.
31. Use the torque wrench to adjust the lash. You have to adjust through full travel. The center of travel, about 2 turns in from the end, should be tighter then the beginning or end of travel.
32. Set the lash torque to between 11-14 inch pounds, lock the nut down on the lash screw. The higher the drag the tighter it will be in the center. I set them for a slight drag and witness mark the position with paint. If I need to adjust on the car to fine-tune it, I now have a starting point. If unsure, then make a second paint mark using a different color of the max setting.
33. The box is now ready to go back in the car. Add the pitman arm, new rag joint, and clean up the three mounting bolts.
Final Notes:
Some of this work does not qualify for NCRS type of judging so you have to decide how to refinish the housing and cover. Most shops will not go to the trouble of machining new bushing so don’t expect a $150-$200 rebuild to cover this. Ask what will be done if you do have some else do the job.
Lastly, this is the way I rebuild these boxes. It pretty much follows the GM overhaul manual so it’s no secret but others may have different methods for this job. My aim is to help other corvette people maintain their cars either by themselves or by
To Steering Box
