Early-C3 Big Block Serpentine Conversion
Old Sep 21, 2004 | 08:37 AM
djunod's Avatar
djunod
Default Early-C3 Big Block Serpentine Conversion
I want to do a serpentine belt system on my '73 big block with A/C. Anybody know of a turn-key solution? Prefer one with a belt tensioner.
Old Sep 21, 2004 | 11:50 AM
Corey_68's Avatar
Corey_68
I ordered this kit Saturday though Summit, they have a 2 week back order. In addition to the kit you need a remote P/S reservoir and later model power steering pump.
http://www.marchperf.com/pg25.html
# 20550
You can pick up the P/S pump from your local parts store (I got mine from O'Reillys). Just pick up one for a 1987 Pontiac Sunfire, cost me $60.00.
Old Sep 21, 2004 | 11:55 AM
djunod's Avatar
djunod
I don't see how that accomodates the AC compressor... in fact the table doesn't have a single YES in the AC column.
I guess you have to purchase the A/C bracket separately...
http://www.marchperf.com/pg8.html
Old Sep 21, 2004 | 12:16 PM
Corey_68's Avatar
Corey_68
yes you'll have to buy the bracket seperate, I don't have A/C so it wasn't needed in my application.
The the #20550 is the kit for our Big Block Vettes.
Old Sep 21, 2004 | 02:31 PM
J. Swisher's Avatar
J. Swisher
http://www.marchperf.com/pg26.html
kit with ac part #20516
Old Sep 21, 2004 | 05:53 PM
70_Shark's Avatar
70_Shark
I cannot help with the A/C, but have the March system. The GM type II pump was a pain to get the right hoses and could never get the fittings to stop leaking. I finally fixed it with a aluminum Sweet pump with AN fittings/SS hoses and a canister with AN fittings. No problems since the upgrade.
Old Sep 22, 2004 | 03:25 PM
timbo79's Avatar
timbo79
The p/s pump is a PIA. I had to make my own lnes to go from metric to standard.... Used a pump out of a '90 vette. Works well, no leaks, just a pain with the double flaring, etc.. Good Luck
Old Sep 22, 2004 | 03:32 PM
Fevre's Avatar
Fevre
About ready to do a sb serp conv with steeriods and the last 2 posts has got me depressed.
To Early-C3 Big Block Serpentine Conversion
