From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
How to locate TDC without a timing pointer?
I have an aluminum timing cover and haven't found a timing pointer that will clear the cover. If I had known this I would have stayed with the stock timing cover. I have every timing pointer offered thru Jeg's and none of them will clear the taller timing cover.
Does this picture look like the balancer timing mark is at the zero mark? I figure an inch back will put me at about 10 deg BTC?? I'm going to have to "eye-ball" this one as removing the cover at this point is NOT an option. In this position, both the rockers on #1 are loose and the rotor is pointing to #1 ( or pretty close).
You need to be a little more precise than "does that look OK". I would get a piston stop for the spark plug hole. Go one way with the rotation and mark the balancer. Go the other way and mark it. Then split the difference and you will have TDC. If you are off a couple of degrees which is not much rotation you will be pulling your hair out trying to time this. I just have a pointer with a fully degreed balancer on mine. I think this works better than having the timing marks on the cover pointer. You should try to be a precise as possible. You have put to much time into this to not be right on.
St. Jude Donor '09
That's what I did to set valve lash when I had the engine on a stand. This is the closest position I could determine as TDC. I went thru the positioning about 20 times. Believe me I'm not "guessing" on any of this. I've gone over all this many, many times. Sometimes trying to "second guess" myself. I had a post before the crash and can't locate it now.
A degreed balancer isn't in the money right now.
Piston (#1) is at the top.
Shouldn't I want startup at some degree of "advanced". (4-10?)
Hard one. If you know the mechanical scale of your distributor vacuum disconnected say 36max-16idle=20 as I have so you might just put the engine on idle and rotate the distributor as long as you find strong/solid idle and keep that setting until you found the exact one...
But if your engine is new to you you may not remember how does it sound and respond on idle etc - then my advise is worth crap
You need to put your tape the other way, I believe its backwards. Try a tavia pointer ,might add a couple of washers to the bolts to bring out the pointer.
I thought that tape looked wrong. I had to go out and look at my car to verify that. Yes you do want some advance on startup. Mine is set at 14 degrees BTC. Going to be hard to set this without the engine running but just bump the dist a little advanced before startup. Once started you can time it from there. They will start when the timing is close.
You can make a temp pointer out of wire, just use one those open bolt holes on the face of the eng to bolt down the wire and bend the wire accordingly. Bubba fer sure but will work until you get one.
I'd definately use the piston stop method,and once you find TDC,do yourself a favor and mark the balancer at 36 BTDC.If you have an 8 inch balancer it's 2.5 inches clockwise from TDC.The timing tape only sticks for a week or so. I went though three sets of tape doing my distributer recurve.
St. Jude Donor '09
Should I determine TDC via the piston, balancer and loose rockers and mark the location? Then move the balancer (counter clock-wise) back a few degrees (BTDC-to get a few degrees BTDC) and then line up the rotor & #1 spark plug wire at the the distributor?
I re checked the piston location are loose rockers on #1.
Get a piston stop (or a bolt with the right thread to screw into the sparkplug port on the number one cylinder.Get the number one piston close to TDC and gently snug the bolt till it stops.At this point make a mark on the balancer and timing cover so that the marks line up.(or get a pointer that fits)Now turn the crank backwards till you again hit the stop bolt.Mark the balancer again to line up with the original timing cover mark.You should see two marks on the balancer and one on the cover at this point. Exact TDC will be exactly between the two marks on the balancer.(Doesn't matter how far the marks end up being apart,TDC will be exactly in the center between the marks.)
St. Jude Donor '09
Thanks Money Pit, I think I got it.
I then backed the balancer off to 8 BTDC and then set up the distributor & rotor based on the new balancer setting. I should be very close if not dead on.
