Guys, how does one gut a catalytic converter...lets say of the 81' year variaty...have heard several ppl do this. Is there any other steps that need to be done to the car once this is done..ie "check engine" light problems..etc. Any info would be greatly appreciated..thanks Joe!
What kind of performance will you see from this? Not flaming just a question. Does it make it increse sound? And im assuming that it wont pass SMOG right? lol
Can't say myself but have friend that did this
What kind of performance will you see from this? Reduced back pressure, some SOTP power increase. Have not dynoed to give you exact increase. Some say 15-25 hp.
Does it make it increase sound? Yes, some. I think it sounds better. Not obnoxious.
And im assuming that it won’t pass SMOG right? No, it won't pass smog check.
I cut the cat out of my 1980 at the same time I installed dynomax turbo mufflers - first I had the shop install the mufflers and I started the car to see how loud it was - then I had them remove the cat all together and I really did not find it any louder ? To me the Cat is just dead weight and is restrictive anyways -
First, you have to catch the cat. I use a rifle, but traps work extremely well also. Then, make an incision from the neck to the a-hole. Reach in there and pull everything out. Don't be squeamish, just reach in and rip it all out! Now, you have just successfully gutted your cat!
