Upper ball joint poly dust boot
Old Sep 21, 2004 | 08:38 PM
Fevre's Avatar
Fevre
Default Upper ball joint poly dust boot
Does it pop down through the a-arm before the ball joint or does it come up from the bottom after the ball joint is in? If it comes from the bottom then the design needs to be changed because it has a ring that allows it so fit perfectly when popped in from the top.
Old Sep 21, 2004 | 08:43 PM
norvalwilhelm's Avatar
norvalwilhelm
It's part of the ball joint, It has a groove in the ball joint and it has to be put on from the bottom over the tapered stud. I don't understand how it could be installed from the top since the top is a flat plate with 3 mounting holes.
Old Sep 21, 2004 | 08:52 PM
Fevre's Avatar
Fevre
Norval
I am talking about the poly dust boot that is a separate peice from the actual ball joint. Maybe I am using the wrong term for it but it is poly and is what keeps the grease in around the joint.
Small pic of it apart from the ball joint (loer one pic here but still the same concept for the upper):
Old Sep 22, 2004 | 04:13 AM
Fevre's Avatar
Fevre
ttt
Old Sep 22, 2004 | 06:54 AM
ewalker302's Avatar
ewalker302
You need to elaborate on what you mean by "before the ball joint", and "popped in from the top".
I dont get what the problem is, if you dont understand how it fits, just look at the one you are replacing.
Old Sep 22, 2004 | 07:32 AM
Fevre's Avatar
Fevre
The ball joint def is installed from the top, my question is if the a-arm is sitting up right, you take the poly boot and insert it down through the top of the a-arm, then insert the ball joint down into the boot or do you insert the ball joint down into the a-arm and boot slides up on the lower part of the ball joint that is sticking down through the a-arm. I am replacing rubber with poly and am uncertain as to whether they install the same way, no instructions are provided.
Old Sep 22, 2004 | 07:40 AM
norvalwilhelm
Why can't you just try it. Either way the ball joint must be seperated from the spindle. Try sliding it up from the bottom first. The groove the boot sits in is below the A arm so it should just slide up. Normally the boot is installed without the joint in the car and then the ball joint is installed from the top. That is with normal boots,
Anyway you look at it the joint needs to be seperated so it is no big deal either way.
Old Sep 22, 2004 | 07:56 AM
Fevre's Avatar
Fevre
Thanks Norval, that is how I did the uppers and lowers def install different, no way the boot is going through the tiny hole in the lower arm. I just wanted to make 100% sure before I torq down the spindle nuts.
Old Sep 22, 2004 | 11:39 AM
NHvette's Avatar
NHvette
Are you saying that if you install the boot first, you end up with
a ring of poly at the top of the boot - sandwiched between the
joint and the control arm ? If so - no way - boot from the bottom.
I stuck with the rubber boots. It seems the poly boots are stiff
enough to possibly pull off under extreme travel. just my $.02
Old Sep 22, 2004 | 11:51 AM
Fevre's Avatar
Fevre
Dave
Yes that is what I am saying. The boot drops down into the arm and the ring molded into the boot below the flange gives it a perfect grommet like fit. There is not distortion of the boot, it fits like it is made to pop in there. But when the spindle is installed there is a gap between the boot end and the spindle so it raised a red flag. I e-mailed Dan at van steele to get clarification.
In a thread regarding ball joint replacement it was pointed out that the upper ball joint sees very little stress so I thought maybe the poly boot was designed to have the flange act as a gasket.
Old Sep 22, 2004 | 12:10 PM
Chumpzilla's Avatar
Chumpzilla
That's strange. I installed new poly boots on my upper joints and the boots didn't have any ring or "flange" on them so it didn't really matter how you installed them. I just installed the joints and slid the boots up on the bottom side.
Old Sep 22, 2004 | 12:18 PM
Fevre's Avatar
Fevre
I can take the passenger side apart easy enough so maybe a couple pics will help people see what I mean.
Old Sep 22, 2004 | 01:43 PM
Fevre's Avatar
Fevre
Seems I have them installed incorrectly, will post pics of the boot if anyone is interested.
Old Sep 22, 2004 | 06:17 PM
Fevre's Avatar
Fevre
In case some cares:
Old Sep 22, 2004 | 06:25 PM
Twin_Turbo's Avatar
Twin_Turbo
If I can give you 1 good advise, stick to rubber boots. The urethane ones may look nice with their bright colors but the urethane is wat toio stiff, mine split without any load on the suspension. The suspension was bolted together for mockup only and after a month or so, both upper ones were split.
JUNK!!!!!!!!!!!!!!!
Old Sep 22, 2004 | 08:13 PM
Fevre's Avatar
Fevre
Actually these feel pretty much like rubber, probably are! I have never seen or felt a poly dust boot but I assumed they would be more plyable than than the actual control arm bushings material.
Old Sep 26, 2004 | 03:08 PM
BigRedRyder's Avatar
BigRedRyder
Navigator
I'm going through the same rebuild and the boots slide on the ball joints after they are riveted to the A-arm. I am staying with the rubber boots, only becuase I'm keeping all the parts original GM.
I'm replacing the front springs on a '74 Corvette with OEM from Chevy. I've tried everywhere else and maybe you guys can help me.
One end has the coils close together, and the other end the coils are spaced apart. I've looked at several cars but cannot see in the spring wells. Can you tell me which end is UP? No one else seems to know.
Thanks in advance.
Don
To Upper ball joint poly dust boot
Old Sep 26, 2004 | 03:27 PM
Twin_Turbo's Avatar
Twin_Turbo
Same material, the stiffness is in the thickness of the material but it will never be as flexible as rubber. The prothane ones are junk, both sides cracked.
Old Sep 26, 2004 | 04:47 PM
stingr69's Avatar
stingr69
I had stock style rubber boots on my replacement ball joints fail in about a year without ever leaving the garage. I bought a set of polyurethane boots in black and they are fine. I have new replacement rubber replacement boots in case the poly boots ever need changing. Must be different levels of quality out there.
-Mark.
Old Sep 26, 2004 | 04:57 PM
PRESSURERAT's Avatar
PRESSURERAT
I wish I saw this thread earlier. I went through the same thing when I rebuilt my front end with energy suspension bushings in '99. Fevre, I suppose you have learned that the boot goes on from the bottom(last), or it will be damaged by the retainer. As I said, my poly boots have been there for 5 years now and about 10,000 miles and none of them have torn. That was Energy Suspension parts.....I am VERY satisfied with all of their components that I used. No squeaks or noises from the bushings, either.
