Fuel Pump Recommendation
Old Sep 22, 2004 | 01:25 PM
Hvymtlc5's Avatar
Hvymtlc5
Default Fuel Pump Recommendation
My 454 is almost complete and back together. It has a strong cam, manifold/750 holley, and headers. Will the stock 23 GPH fuel pump be enough to handle the gas requirements, or do I need to go to a higher flow 123 GPH Holley pump (for example)? Only want to buy new parts once ...so I appreciate the advice.
Old Sep 22, 2004 | 01:58 PM
BB wowbagger's Avatar
BB wowbagger
I use a Holley Streetpump that works really well with my 461. It deliveres 110Gph at about 6-7 Psi..No need for a regulator..
Old Sep 22, 2004 | 02:12 PM
Ironcross's Avatar
Ironcross
Stock fuel pump with a 3/8`s line will work just fine. It will handle 550 HP+. L88`s, ZL1`s, and LS7`s included.
Old Sep 27, 2004 | 08:15 AM
Hvymtlc5's Avatar
Hvymtlc5
Stocl pump it is...saved a bunch of bucks this way - thanks!!
Old Sep 27, 2004 | 08:44 AM
Fevre's Avatar
Fevre
When I replaced my stock sb pump (new one is prolly a foreign part) I put a clear glass filter in just to see what was going on, it captured some rubber (probably from the internal seal) and some other gunk. I would put a filter in at least temp for a little while or have it pump into a bucket for a few cranks of the eng to flush it out.
To Fuel Pump Recommendation
