I just purchased an 81 Corvette that is in need of some serious help. I am pretty much a beginner when it comes to working on cars. Can anyone tell me how to take the body off the chassis so I can have access to work on just the chassis?
Here are the detailed steps we use in the CCC (The Colorado Corvette Crazies - the Ultimate Corvette Tuning and Beer Drinking Fraternity):
1. Get the guys together and have a couple of Bloody Marys for breakfast.
2. Drink two beer chasers.
3. Unbolt the body.
4. Have 2 beers.
5. Spend 30 minutes trying to get the drunken idiots to divide into 2 even groups, one on each side of the car, without anyone taking a potty break from all the beer.
6. Take the body off and set it on the body dolly.
7. Send the most sober guy to the liquor store for more beer.
8. Drink the beer and smoke cigars.
9. Get chewed out by ticked off wives for being drunk and smelling like cigars.
The last one we did took about 50 minutes to pull the body off the frame and set it aside. We then spent 8 hours on the other operations...
I agree with Lars, except they should be Cuban cigars. You cant have an event like a body-off resto and smoke a Swisher Sweet!
Seriously though, there's only 8 bolts holding the body on. Youve done a ton of work already, why not go all the way!
Why does the body have to come off the frame? From what I can see, it otherwise looks pretty straight. My advice would be not to underttake the operation without doing your Corvette homework. There are several existing reference publications available through the aftermarket providers which explain the process. Look before you leap.
The reason for taking the body off is to try to stop the frame from rusting. It is only surface rust that I can see, but I don't want to leave it untreated. I agree with your theory look before you leap, but do you have any suggestions on some books I can buy?
Oh and by the way, what do you think of my garage? I built it myself!
Suggest you use straps that go under the body, pick it as close to each door jamb as you can. I would not trust the lifting strap kits that hook into the rocker channels unless you are 100 percent certain the rocker channels are not rusted out. Serious body damage can result. Be certain to provide some support under the nose once the body is off, leaving the radiator support in place will help strengthen the nose and provide a good place to add support.
I just did mine two weeks ago. There are more than just eight bolts. There also is:
ebrake cable (3-4 different bolts and nuts)
steering linkage
antenna ground strap
coil wiring
front bumper brackets (multiple attachments)
then the 8 body bolts
This is for a 69 btw.
Nolland Adams has a tape which is a good guide once you get past the fact that he makes annoying comments about unrelated corvette facts and the poor editing quality of the tape.
Record your shim placement for when you put it back together.
Get/make a body dolly to put the body on (this is a really good thing to have.)
You might want to double check the width, the guy that came up with these plans said it was about 1 inch too narrow, and had to make some quick modifications to get it to work for his car.
You are one ambitious beginner…good luck…I’ll be watching your future post. Any details on your car…notice it has the T-top carrier holes on the rear deck. Oh, and your garage is good to go…for now, might get a little chilly in Ohio in the coming months…
Where is "near" Columbus? I live in Wooster. I, too, am a beginner and am always watching for another enthusiast nearby. I'd love to learn on someone else's car.
I live in Lancaster. It is probably 2 hours away from you.
The only way to learn how to work on your car is to get a good service manual, a factory assembly manual, some good tools and dive in. I would have liked to have learned on a Vette, but my 68 Chevelle was more in line with my budget back in the early 70's. Taking lots of pics will come in handy when it's time for it all to go back together, but a factory assembly manual is the best reference. Develop a plan and do your best to stick to it. Good luck working on it in the winter.
