Clutch Return Spring??
Old Sep 23, 2004 | 02:54 PM
mike229's Avatar
mike229
Default Clutch Return Spring??
You all helped me fix my clutch earlier in the week - the 2 nuts on the rod came loose and it was an easy fix!!
There is a "return spring" apparently running from the rod to the firewall - I do not have this spring - do I need it? Is there anything functionally wrong without having it? Seems ok but just want to know what its for...
Thanks!
(71 454 M20)
Old Sep 23, 2004 | 03:06 PM
Fevre's Avatar
Fevre
It pulls the throw out bearing away from the clutch fingers, the weight of the clutch pedal will make it ride on them all the time shortening its life, I would find a replacement spring
Old Sep 23, 2004 | 03:16 PM
mike229's Avatar
mike229
Thanks again Ferve! You da man - always a good explanation!
Also - if I want to try a universal spring to save time/$, about how many inches is the spring?
Thanks!
Old Sep 23, 2004 | 03:23 PM
wcsinx's Avatar
wcsinx
Just FYI, it hooks to a little hole towards the bottom of the steering column plate. I racked my brain forever poking around there with a flashlight looking for a hole before I finally wised up and asked the CF.
Old Sep 23, 2004 | 03:27 PM
mike229's Avatar
mike229
Thanks wcsinx! - also - im not at home where my car is - but where does it hook to on the other end?
Also - About how many inches is the spring?
Old Sep 23, 2004 | 03:54 PM
1yy07's Avatar
1yy07
your spring GM#3921656/spring, clu ped pull bk
To Clutch Return Spring??
