A/C Vacuum Switch Testing
Old Sep 23, 2004 | 03:52 PM
nunes81's Avatar
nunes81
Default A/C Vacuum Switch Testing
Does anyone know how to test the a/c vacuum switch in an 81 vette?
Old Sep 23, 2004 | 09:24 PM
Ganey's Avatar
Ganey
Just press it together to test w/ vac. going to it.
If the vac. switch itself is not switching due to vac. leak, the usually plastic rivet is not holding the 2 main switch parts together well. Besides replacing, it is also possible to tighten this &/or lube w/ a thin layer of white lithium grease or vasoline to fix.
