tach problem on my 78
Old Sep 23, 2004 | 04:53 PM
kidneyboy's Avatar
kidneyboy
Default tach problem on my 78
Tach suddenly just stopped working. But when I start up the car or turn the key to "on" the tach jumps a bit then returns to dead. Any ideas?
Old Sep 23, 2004 | 05:25 PM
kona's Avatar
kona
I had this same problem last month. Turns out the Tach Filter was bad.
Look near your distributor it will be mounted on the intake it is silver about two inches long with one wire going in and one wire coming out.
Not sure how you test them but that was the culprit in my case. They are about $50 in the catalogs or you can search for Rodney Dickman on the web and he sells them for $20 plus $5 shipping thats where I bought mine.
You can even do a search on the forum I think at one time someone posted plans on how to make one.Hope this helps.
Kona
Old Sep 24, 2004 | 12:29 AM
ACECO's Avatar
ACECO
St. Jude Donor '04 & '05
Here's a schematic for the tach filter.
Parts can be had at Radio Shack, or any electronics house.
Hope this helps. Good Luck!
Old Sep 24, 2004 | 09:04 AM
kidneyboy's Avatar
kidneyboy
Default thanks
I think that may be it, thanks for the response and the schematic. I'll let you know how things work out,
Old Sep 24, 2004 | 05:08 PM
ACECO's Avatar
ACECO
Just use a jumper wire across the filter to test it. If the tach starts working, then the filter is probably bad. If not, then you will have to look elsewhere.
Good Luck!
Old Sep 24, 2004 | 05:19 PM
Lotus76's Avatar
Lotus76
Thanks for the info,
heres the link http://www.rodneydickman.com/retail.html
Two styles
John
Old Sep 24, 2004 | 08:09 PM
fastback01's Avatar
fastback01
Cruising
Default Bad Tach
Good responses..........esp the radio shack advise..........
Old Sep 24, 2004 | 08:21 PM
MIKER's Avatar
MIKER
Here's another pic of the schematic.
http://www.corvetteforum.net/c3/eddlemsg/tachfilter.gif
I had to build one once.
Tach filter. Wire broke off. Need replacement advice.
http://forums.corvetteforum.com/show...highlight=tach
Old Sep 25, 2004 | 01:50 PM
kidneyboy's Avatar
kidneyboy
Default thanks for the tach help
With all the advice out there from everyone, found the problem a fried wire leading from the filter, rewired it and soldered back, works like a charm. Thanks to all you guys agin for the advice and help.
Old Sep 25, 2004 | 02:02 PM
76REDSTINGER's Avatar
76REDSTINGER
Radio Shack NOW sucks......they dont have anything anymore
went there today dont have 100pf cap and they cant get it
they used to be good.
R.
To tach problem on my 78
