Pulling a vacuum for a/c conversion
Old Sep 23, 2004 | 07:36 PM
Wrecked82's Avatar
Wrecked82
Default Pulling a vacuum for a/c conversion
How about hooking up a hose to the low pressure valve and the other end to a vacuum port on the manifold. Yeah, so I am pulling freon, oil and moisture through the manifold. Is that any different than a PCV valve?
Old Sep 23, 2004 | 07:47 PM
shoptek's Avatar
shoptek
That would work, but your engine will probably only pull 18 or so inches of mercury, not the "desired" 28-30 inches.
Old Sep 24, 2004 | 05:34 AM
Larry B.'s Avatar
Larry B.
I've done that. It will get the air out, but will not boil out any moisture since you need 28"hg or better to remove moisture. Getting the air out is a must.....If you live in a dry climate and the system hasn't been open too long moisture shouldn't be a problem. I don't know what will happen to you Catalytic coverter though. They are sensitive to lots of stuff.
Old Sep 24, 2004 | 09:26 AM
Jim Martley2's Avatar
Jim Martley2
This is NOT such a good idea!! When you put "freon" thru any type of combustion process it turns into a type of "nerve gas". BAD STUFF!!!!
Old Sep 24, 2004 | 09:35 AM
PRESSURERAT's Avatar
PRESSURERAT
You can rent those vacuum pumps from Auto Zone.
Old Sep 24, 2004 | 12:25 PM
Missileman's Avatar
Missileman
Both R12 and R134a turn into Phosgene (re:nerve) gas at temperatures above 260 degrees. If you do this, please don't do it in a garage.
Although 28" is best to remove the majority of moisture, the GM shop manual only requires 14" for 45 minutes. This assumes that any additional moisture will be assimilated in the dessicant bag of the receiver/drier if it is not already saturated. So technically you could evacuate your AC system with manifold vacuum. Personally, I would not recommend it because of the availability of cheap sources of vacuum pumps (Harbor Freight, auto parts rental, etc.)
My .02
To Pulling a vacuum for a/c conversion
