Lost in paint...
So this afternoon I head to the paint store and ask for primer. So the guy asks me what kind of paint was on the car and since I don't know I told him it was laquer or enamel which were normal in that time. (btw, the car is 2 tone and was repainted at least once)[EDIT] Thought about it and it must be enamel cause I used thinner to remove sticker glue and the paint wasn't affected[EDIT]. He then tells me I need to strip it down to the gel coat cause no 2 component primer will work on that... so I tell him I'll do so and still need the primer so he gives me a 4:1 grey urethane primer with catalyst. Its a noname brand so I ask him if it will react well with dupont basecoats (thats what I'm going with) and he says it doesn't matter, it'll work with any basecoat.
So what gives? Is he right? must I strip the car down? Its all smooth and nice right now...begging for primer. Oh and some other guy told me I need to put something special (can't remember) on the primer before the basecoat cause of my paint choice (dark metalic grey) or else I will see through the paint.... ?
Anyway... really not impressed by the paint companies... why is this so complicated? sheessh... Thx for the help guys, I know you'll make it all clear for me!
There are many types of primers and sealers out there that you should be able to find something to cover enamel or laquer and paint the car with urethane or whatever you want.
You have to use the correct primer if you're not sanding down to gel coat, as certain primers will permeate the old paint and cause it to bubble down the road. I would get a second opinion, preferably from someone that physically paints cars....not just that works at a paint store.
I am doing the same to mine. about halfway through sanding the body with 180....will have some small areas to glaze. I have not yet bought primer (not ready for it), but will in the next month. 4 coats of primer....sand it smooth.....and ready for paint in the spring!
If you're using PPG...use every and all PPG products, sealers, surfacers, primers, and color coats. Don't use some "generic" primer/sealer. Don't use another company's primer with yet another company's color coat. Chuck
