10" Wide rims
Old Sep 25, 2004 | 09:06 AM
hirevroller's Avatar
hirevroller
Default 10" Wide rims
My tire and wheel guy wants to slam a set of 10" wide american racing wheel 15" I was wondering if anyone on here has 10" wide wheel and if so does everything clear. I wouldn't mind so pics to.
Thanks Guys
Old Sep 25, 2004 | 09:12 AM
killervette666's Avatar
killervette666
Worst case scenario you can always get wheel adapters from VBP that would let you fit any wheel up to 11 inches wide (if not wider, havent tried it yet), i have 17 by 11 inch rims with 315 tires out back and 275 out front (going to swap the front ones for 315s as well) and with VBPs 3 inch wheel adapters they fit on perfect, you just might need some fender flares, and thats never a bad thing
Old Sep 25, 2004 | 09:29 AM
hirevroller
Good deal thanks are where might I be able to find a set of these fender flairs
thanks
Old Sep 25, 2004 | 11:01 AM
76REDSTINGER's Avatar
76REDSTINGER
ecklers has the flares....pricey though....$500-$600
i have 10" rims on the back of my 76.
Old Sep 25, 2004 | 03:10 PM
hirevroller
Could you post a pick for me to see. Thanks
Old Sep 25, 2004 | 08:13 PM
killervette666
I ended up making my own, youll see a post soon by me about how to do it yourself, its very easy and painless and will only cost you $60 All that you need is a product called tigers hair, or bondo hair. Its like bondo, except its reinforced with fiberglass fibers making it 500 times stronger (i can fully sit on the fender flare i made), you get a big piece of metal and make it fit to your wheel arch, then build it up unto the lip of your wheel arch until you get approximantly the right dimensions you need, then just sand it down (the fiberglass makes it real chunky and rough), fill any holes or dimples with a bit of bondo and youve got your set of custom made fender flares that look exactly like what you want them to look like. Getting them even isnt that bad either. Hope this helps you out
PS: Sorry i cant get you a pic, my scanner crapped out, ill get some pics some time next week and send you a pm.
Old Sep 25, 2004 | 08:23 PM
79VetteMike's Avatar
79VetteMike
I wanna see too!!
Old Sep 25, 2004 | 08:35 PM
Sharky Guam's Avatar
Sharky Guam
Thanks Guys
I have a set of 10 inch wide billet wheels on all four corners on my 82. I bought the car with that setup. It does not look too bad. But it seriously rubs on tight corners. The rubbing is on the front side of the wheel openings. I would not reccommend it without some trimming. It does not look bad and does not need flares. I am not sure of the offset. But it looks like 4-1/2 backspacing.
Old Sep 25, 2004 | 09:00 PM
7d73tt3v's Avatar
7d73tt3v
I have 15x10's on all four corners and have no problems at all. Running 235x60's on them.
Old Sep 25, 2004 | 10:12 PM
Summerfun's Avatar
Summerfun
Thanks Guys
I'm running 9,5" wheels with 1,5" spacers in the rear and 285/40/17's
Works great!
Old Sep 26, 2004 | 09:49 PM
hirevroller
Hey could I please see some pics guys of the 10" wide wheels
Old Sep 26, 2004 | 10:00 PM
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
10" rallys with 5" backspace on the back. 295/50/15 BFGs.
same tires on 8" stock rallys on front.
Old Sep 26, 2004 | 11:14 PM
79VetteMike
Do you have any mods done to your suspension Turtle?
Old Sep 26, 2004 | 11:35 PM
Corey_68's Avatar
Corey_68
Why such a small tire on a 10" rim? I'm running 275/60/15 on a 8" rim.
Old Sep 27, 2004 | 08:47 AM
turtlevette
i relocated the e-brake bracket. No suspension mods.
Old Sep 27, 2004 | 09:17 AM
norvalwilhelm's Avatar
norvalwilhelm
Thanks Guys
Not a chance without flares unless you are willing to let the tires hang out the side. I did alot of research this weekend with 10 inch by 18 inch american racing wheels and even with 5 inch backspacing which most people can not handle the wheels stick out the side of the car by about 1 inch. I have knotched trailing arms, modified frame and coilovers to get rid of the buggy spring that interfers with 5 inch backspacing. I can handle 6 1/2 inches of backspacing and that is what is needed to tuck the 10 inch rim under the fender.
Old Sep 27, 2004 | 01:39 PM
The Money Pit's Avatar
The Money Pit
This shot is looking at the edge of a P295 50 15 mounted on 15X9 Weld Draglites. The rim has a 5 1/2 " backset,but I installed a 1 1/4" VB&P wheel adaptor to make up the difference. I could not find a 15" rim that had the 4 1/2" BS that I needed,but in a 9' width. I tried 10's ,but as Norval said,they stick out an inch past the fender lip,which for me was not an option.This combination has been on my 80 for two years and I've never had any clearance problems at all.
Old Sep 27, 2004 | 02:37 PM
gkull's Avatar
gkull
My question to the poster is why does your tire man think that you need 10X15 wheels?
Killervett666 - I can't imagine 315's on the fronts That would really be putting some severe torque on the front end. If you could please email your flare ideas. The only thing that's stopped me from flares is having to redo my custom existing paint job.
To 10" Wide rims
