Check those vacuum hoses
Old Sep 25, 2004 | 10:34 PM
SLine78's Avatar
SLine78
Default Check those vacuum hoses
Was doing some minor cleanup under the hood on the 78 and had removed the air cleaner when I noticed a couple of the vacuum hoses on the carb had become brittle and split. One was the small hose going to the choke pull-off and the other was the ported vacuum hose going to the distributor. Big improvement after replacing them.
On a Quadrajet, doesn't a non-functioning choke pull-off also effect the opening of the secondaries?
Mike
Old Sep 26, 2004 | 08:45 AM
Steve's74's Avatar
Steve's74
Yes, a defective pull-off can allow the secondaries to open too fast.
Steve
