From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Anyone know wha causes this ?
I have been keeping an eye on the roller valve train and noticed that two of my rockers are wearing the side of tips a little. It looks like the roller is wearing a groove on the insde and there is about 45 thou play as opposed to all the others at aroung 20 thous.
All of the other rockers look brand new except the two on #4 and when they are pushing the valve down it looks like they are off center of the valve stem. I did notice a couple more that were off center but there was no wear like the ones on #4.
I am thinking guide plates because both bad rollers are on the same cylinder, but thought I would throw it out there as sometimes somebody knows exactly what the problem is
BAD ONE
GOOD ONE
you arnt running guide plates not a good idea with roller rockers. you can but you take the chance of this happening. i would install guides and cromoly rods to fix that prob. well good luck and let us know if it helps. also if you add guides and chromoly rods and are gonna use the same roller rockers move them to a different cyl and put good ones on that cyl to make sure it isnt a bigger issue causing the wear.
No I am runnig guide plates, I meant that I thought they needed to be adjusted. I have a complete CC Hi Tech roller valve train with 80 wall pushrods, solid roller lifters etc.
I was thinking that because the two bad rollers are on one cylinder the only thing in common is the guide plate.
I have to agree with Fevre. Guide plate are not just a bolt on part. They have to be adjusted to align the rocker over the top of the valve. Many times they require the mounting holes to be slotted with a die grinder to get the proper alignment. Even with the shaft mounted rocker that I use, you have to shim the rockers right or left to get the proper alignment over the top of the valve.
No no the roller is responsible for the wear it fits right in there, the picture is throwing you off. I don't think it is a defect because there are only 2 bad ones and it is too much of a coincidence for them to be on the same cylinder.
I think I am going to adjust the guides plates, It is still kinda wierd though because there are other ones that are a little out of alighment and they are OK. It's like there is more pressure on side forcing the roller into the side of the tip.
I will throw a couple of pennies in the pond. Rockers will not be perfectly center to the valve they will be just a hair off usually. I would probably take the effected rockers back and get them replaced as it looks like the roller tip itself is defective as it may just be too soft or even too hard. Hard to tell by the pic. And no if I were you I would not go back to stamped steel rockers. And yes check the guide plates as well.
