What is a holeshot win?
Brett
If you and I have dead-nuts identical cars, who gets to the finish-line first?
Answer: the driver who 'left' first, with-out red-lighting.
ET is the time the CAR took to travel the 1/4-mile;
RT is the amount of time after the Green bulbs glow until the car actually MOVES from the beams, OK?
Which pair are you reffering to?????
Lemme see if I have this right. Even though the winner had a slower ET, he arrived at the finish line first because he left the start line first. Right?
We stage, the lights come down, and you leave IMMEDIATELY as the Green light glows...
You run (pick an ET, 13.000, OK???)
I wait a half an hour, then leave the starting-line, and I run 13.000, correct?
The 'margin-of-victory' would be 30 minutes (a half-hour), the difference in our REACTION times...
http://www.dragracecentral.com/DRCStory.asp?ID={29D0B134-2E21-4247-966C-957AB695D1DE}&Filter=100#indextop
should be 2nd Round Pro Stock Eliminations.....
Check-out the 2nd pair down, Allen Johnson beating Steve Johns...
Johnson cuts an .028-light, and runs a 6.850;
Johns runs .029-seconds quicker (6.821), but got left-on by .050 ( Johns' RT was .078)...
There-fore, Johns lost by .021 (.050 dis-advantage on the Tree less .029 in performance = .021 Margin-of-Victory).
If you saw Saturday's Top Fuel qualifying on TV, a pair of racers ran IDENTICAL ET AND MPH (4.625 @ 324.75), side-by-side!
Whoever left first hit the stripe first, by virtue of his RT.....
In a competitive class like PS, this happens fairly-often;
when you get a driver with better-than-average RT-skills, coupled with superior performance, like Greg Anderson the past few years, you can see where they'd be tough to beat.
Even when GA does get 'left-on', it is rarely by more than .02, and his car is 'usually' .03 quicker than the field, so GA 'drives-around' them anyhow, but, more often-than-not, GA leaves 'with' his opponent.
GA, his team-mate Jason Line, and rookie Dave Connolloy are amongst the best 'leavers' in the class, while Warren "the Professor" Johnson is traditionally one of the slowest-reacting drivers in the class, with WJ preffering to build power and 'drive-around' his opponents if he can.....
If you saw my avarage RT's you'd know why!!
