Engine fans.
Old Sep 27, 2004 | 07:06 PM
hensen1954's Avatar
hensen1954
Default Engine fans.
Couple of quick questions.
On my 81 350 and my friends 71 454 ( new fan clutches looking pretty ) just how much bhp is used to turn a Vette fan.
Because, standing there with the hood up - it feels like about 30 bhp at 2,000 revs.
Any accurate figures ????????
Next point, Daves 454 - lotsa new parts including headers, and it accelerates like it has about 180bhp - not the 400 quoted for his engine as is. Now, I know its way outa tune carb wise, but anyone tell me the 0-60mph time for a 1971 454 auto - otherwise standard ??
Cheers,
Hugo.
Old Sep 27, 2004 | 07:48 PM
Boofers's Avatar
Boofers
First, 'they' say you gain between 5 and 10 horsepower when you replace your belt driven clutch fan with an electric one.
Second, don't know the 0-60 time you are asking for but there were two different big block engines available that year, the LS5 (365hp) and the LS6 (425hp). These links may help you identify which one...
http://www.netvettes.com/1971.html
http://www.stingray.nu/tips/tech.htm
Old Sep 27, 2004 | 08:35 PM
hensen1954's Avatar
hensen1954
Read this lot..........................
http://www.kenlowe.com/fans/consumers/fans03.html
Old Sep 27, 2004 | 09:22 PM
1979toy's Avatar
1979toy
Sounds like a company that is trying to sell electric fans. You expected anything less?
When I put electric fans on my 350 I noticed that the engine did seem to rev faster and that the fan noise was greatly reduced. With the engine off and the fans running I can feel a vibration throughout the car in addition to hearing the fans.
Old Sep 28, 2004 | 03:25 AM
hensen1954's Avatar
hensen1954
did you find it any better on performance or gas consumption.
I changed my big block Cobra to electic fans, many years ago, and more recently the E Type Jag.
The Vette fan is much bigger than either.
The previous owner put a Kenlowe on the BMW732i, and I noticed I only need it when stuck in traffic on a hot day.
Anyway, most of my driving is done fast on the open road - very fast sometimes..............
Old Sep 28, 2004 | 10:50 AM
mandm1200's Avatar
mandm1200
I don't think it takes more than a couple of hp to turn a fan. I suggest you find an electric 2 hp motor, grab a hold of the front pulley very hard, and the have someone turn the motor on. You'll get an idea of what force 2 hp is like. One of the advantages of a clutch on the fan is that at crusing speed there is suffcient air flow through the radiator and the fan is not needed.
There is no free lunch with an electric fan. Once it kicks on, the alternator is reguired to put out more power. It then puts a strain on the engine and uses some of the hp of the engine to produce the power.
Old Sep 28, 2004 | 11:00 AM
zwede's Avatar
zwede
Non-clutched fans (rigidly mounted to the w-pump) can draw over 20 hp. A clutch fan is typically around 10 hp at high rpm.
Electric fans are a good thing for several reasons:
Max output regardless of engine speed. You need the cooling most going slow in traffic, where an engine driven fan gives you the least airflow.
Only runs when needed (as long as you have it thermostatically controlled).
Less power draw even when running. The big fans use 25A... at 14V that is only 350W. 1 hp = 738W so about 0.5 hp. Add in some losses in conversions (alternator) and you're still looking at less than a 1 hp draw on the engine.
Old Sep 28, 2004 | 12:16 PM
markdtn's Avatar
markdtn
I have posted this before but:
Car Craft test, May 2000 issue, page 50-51.
No fan=496 hp
thermal clutch fan 487 hp
HD thermal clutch fan=476 hp
non-thermal clutch fan=485 hp
plastic flex fan 460 hp
HiPerf flex fan 476 hp
lo Profile flex fan=466 hp
6-blade rigid=449 hp
electric fan=494 hp
4-blade rigid=473hp
Old Sep 28, 2004 | 12:23 PM
djunod's Avatar
djunod
I'm more worried about engine temperature then I am about a little bit of horsepower loss... on my '73 I have dual electric fans and a clutch fan... what good does a few more horsepower do you if the engine overheats?
Old Sep 28, 2004 | 12:25 PM
hensen1954's Avatar
hensen1954
Thanks - at last accurate figures.
And now I can tell the world - just around the corner from my garage is the big green wheelie bin for my brothers hotel - do you think he will notice a C3 fan hiding in there somewhere.
Cos these figures echo those of the Kenlowe fan people.
So, its roller everything, cold air everything and electric everything
Look out Porche - we're coming to get you..............
To Engine fans.
