Ignition Wire Set options/recommendations? OE? Repro?
Old Sep 29, 2004 | 12:47 AM
C8H18's Avatar
C8H18
Default Ignition Wire Set options/recommendations? OE? Repro?
Am considering...
A) The 'correct' reproduction Packard TVR wires from LectricLimited or
B) Current service replacement 'Delco' wires from GM dealer (probably gray or black I think) or
C) Other... Comparable... Similar... ?
This is for an early C3 SB w/ the points replaced by an electronic ignition kit (under the stock cap). I typically run AC plugs 44s or 45s and nothing real radical as far as timing or performance or anything.
I'm NOT looking for anything that is 'loud' or 'bright' or has crazy HP claims. I'm looking for good quality functional wires that are known to last, not leak and are not 'noisy'(probably not an issue w/ most modern wires). I wouldn't mind 'correct' wires and if all things are equal given a choice that would be the way I'd go.
Any recommendations along these lines?
Old Sep 29, 2004 | 01:07 AM
PRNDL's Avatar
PRNDL
Originally Posted by pgtr
Am considering...
GOT THOSE
GOT THOSE TOO - BRAIDED BIGBLOCK
Got a set of 8mm black wires from Summit, also a set of 7mm cheapo from the parts store..... they all work
Old Sep 29, 2004 | 01:19 AM
comp's Avatar
comp
are your's bad??
Old Sep 29, 2004 | 03:04 AM
stingr69's Avatar
stingr69
I do not think the current Delco replacements are exact. They do the job though. Black boots without the top retainers for the distributor ends but otherwise I cant complain. The cables are gray with the date codes. I bought a set from the Dr. and they work fine.
-Mark.
To Ignition Wire Set options/recommendations? OE? Repro?
