Try to isolate the problem. I usually put a timing light on each spark plug wire to see if I can see the "miss". Then I can pull that plug or wire or check the distributor cap. If you find nothing, start looking at the carb for fuel float adjustments, reset idle mixture screws, etc.
Spark plug wire grounding out? I remember having trouble with an engine miss on a 79 L82 that got progressively worse with RPM. Tried all kinds of things - no luck. When I went to replace the cap and rotor that were nearly new, I found a hairline crack on the rotor near one of the attachment screws. When I changed that, the miss went away! I couln't believe it!
Did you recheck your valve lash now that you have some run time on the motor? You can pull one plug wire at a time and see which causes the least change in idle quality to try to determine which cyl might the culprit. Once good thing about a Chilton's manual is that it has a section on eng diagnosis with a vac gauge, very handy. I can scan and e-mail it to ya if you like.
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Run time??? I think I maybe have 40 min of run time. Most of that was spent looking for leaks.
Chilton's? But then I'd have to take time to read a book. No I didn't re-check valve lash, just retorqued the head bolts.
Thanks, I'll check on some of those ideas.
I do have another carb, but it's brand new and you know how finicky new parts can sometimes be. I was hoping to get all the bugs worked out with this carb since it has worked flawlessly on my SB....its a 750 Holley 3310.
Then don't touch it, don't work in too many different directions a once.
I would look at wires, plugs etc first. Pull the plugs and see if any are significantly different to track down the offending cylinder.
After it warms up, put it in drive while holding brakes on and apply a little throttle. If engine misses under the load it usually has been a defective plug wire from my experience. As mentioned by others, a crack in the insulation or boot allowing the fire to jump to a ground. For some reason the problem is usually worse when hot or under engine load, probably because of higher resistance. I have also had luck with looking at the wires while the engine is running in complete darkness, such as in the garage. Just remember to leave the garage door open. Good luck...let us know what you find.
St. Jude Donor '09
Guess I'll have to put the driveshaft back in first.
