How to get R12 Certified ?
Old Sep 30, 2004 | 11:13 AM
Pete76Shark's Avatar
Pete76Shark
Default How to get R12 Certified ?
Guys I went to 2 auto parts stores and they have no clue how to get R12 certified.
Does anybody have information on this ?
Old Sep 30, 2004 | 11:17 AM
81 Vette's Avatar
81 Vette
St. Jude Donor '05
First C3 General Poster!
I do my best to make sure no aspect of my cars are either a: legal or b: certified hahaha. Sorry bro.
Old Sep 30, 2004 | 12:06 PM
gerry72's Avatar
gerry72
Contact one of your local A/C repair shops. They usually do or know who does the mobile A/C cert training. It's really a bonehead requirement. The class is so basic (Is it: a) okay to release the gas, or; b) not okay to release the gas into the environment) that it can't possibly be of any benefit to the environment. Takes about two hours and they send your test off to the EPA, who sends you your license. I did mine about ten years ago and I doubt things are any different.
Old Sep 30, 2004 | 12:21 PM
zwede's Avatar
zwede
Here's the exam:
http://www.epatest.com/e_home.html
Old Sep 30, 2004 | 12:24 PM
markdtn's Avatar
markdtn
Yep, do a search for "macs". Thay have a similar deal. Open book test with a manual that if you have read, you should be able to ace the test.
Old Sep 30, 2004 | 01:13 PM
Pete76Shark
Originally Posted by zwede
Old Sep 30, 2004 | 02:32 PM
SpyderD's Avatar
SpyderD
Yeah your local HVAC wholesale parts store will usually sponsor classes and the exam. Give them a call.
Old Sep 30, 2004 | 04:46 PM
Pete76Shark
I just finished taking the test and I passed it..
Very interesting reading in the manual I downloaded.
--> There is no "drop-in" replacement for R12
--> Residual chlorine from any CFC (r12) left in the a/c system will cause serious chemical stability problems in R134a systems.
--> POE and PAG oils which are both used with r134a are not compatible with each other.
--> Recharging a "blend" (freeze12 and hot-shot are 2 examples) is also quite different, you must always recharge as a liquid.
--> Mixing lubricants can cause serious a/c system problems.
--> The proper amount of lubricant is also a very important consideration. If overcharged with lubricant, the system will become oil logged and less efficent, delivering warmer air, or may result in premature compressor failure..
The over the counter r134a conversion kits do not deal with the old oil that is left in your a/c system. So if you put in a new oil and refrigerant load you could easily end up with to much oil. No wonder r134a has a bad reputation
Anyway I learned a few things by taking the time to read the book and take the exam. Well worth the $20 bucks. And the chart on page 29 that shows what the blends are made of is great.
goto page 29 (page 41 in Adobe) and check this out...
http://www.epatest.com/609MAN.pdf
To How to get R12 Certified ?
