From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Painting over chrome?
How easy is it to paint over something that is chrome. The piece is old and flash chrome. Can I just roughen up the surface with some fine steel wool and paint?
You sure can. Just make absolutely sure that the chrome isn't flaking off at all. If a small part has flaked off then there's a possibility that another part will flake off a few months down the road, taking a scab of paint off with it. Don't ask how I know this!
Some bike manufacturers used to paint directly over chrome as a matter of course (eg BSA). Flash chrome has a slightly rough surface so the paint will grip OK, show chrome will need to have a decent primer applied to it to give adhesion (it's called an etch primer here, don't know what you guys would call it). If you use a "normal" primer then you'll be able to scrape the paint off with your fingernail when it's dry. I suppose roughing it up 1st would help, but I couldn't bring myself to take abrasives to show chrome - it'd be like drawing fangs on the Mona Lisa!
